Physics lab normal force please help!!!!!
by albarnett17
Tags: force, normal, physics
albarnett17
albarnett17 is offline
#1
Mar9-12, 10:02 AM
P: 8
A 1000-kg car moves at a maximum speed so that it does not skid off the 50-m radius level track. If the coefficient of static friction between the road and wheels is 0.80. What is the maximum speed? Assume that the gravitational constant is 10.0 N/kg =10.0 m/s. Use the simulations in 4.5 Car Circles a Track to check your answers.
Write an equation for the vertical y-component form of Newton's second law. Determine the magnitude of the normal force. Then use a force law equation to determine the magnitude of the static friction force.
Write an equation for the radial component form of Newton's second law. Use this to determine the maximum speed that the car can travel so that it does not skid (so that friction can provide the needed force to keep the car moving in a circle). Once you have calculated the maximum speed adjust the speed slider in the 4th simulation to this speed and see if the car stays on the track.
Phys.Org News Partner Physics news on Phys.org
Physicists consider implications of recent revelations about the universe's first light
Vacuum ultraviolet lamp of the future created in Japan
Grasp of SQUIDs dynamics facilitates eavesdropping
tiny-tim
tiny-tim is offline
#2
Mar9-12, 10:16 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi albarnett17! welcome to pf!
with these questions, do everything in the order the question tells you to
start with
Quote Quote by albarnett17 View Post
what do you get?
albarnett17
#3
Mar9-12, 10:52 AM
P: 8
Idk any equations or where to put what in the equations i have no idea how to do this.
tiny-tim
tiny-tim is offline
#4
Mar9-12, 10:57 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
in other words:
draw a free body diagram
mark all the external forces on it
then do F = ma in the vertical direction
what do you get?
albarnett17
#5
Mar9-12, 11:08 AM
P: 8
Ok i did i have a diagram but i still dont get sorry but i really do not kno like almost anything in physics
tiny-tim
tiny-tim is offline
#6
Mar9-12, 12:08 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
ok, now we have to do F = ma vertically (in the y direction), from your diagram
a (acceleration) vertically is obvously zero, and your only vertical forces are the normal force N, and the weight (which you're calling V, but we usually call it W)
ok so what is the equation (with the numbers in)?
albarnett17
#7
Mar10-12, 04:26 PM
P: 8
F=10000*0
f=0
tiny-tim
tiny-tim is offline
#8
Mar10-12, 05:15 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
what's F?
albarnett17
#9
Mar11-12, 11:01 AM
P: 8
f= 0
tiny-tim
tiny-tim is offline
#10
Mar11-12, 11:09 AM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
yes, but what is F made of?
albarnett17
#11
Mar11-12, 12:00 PM
P: 8
Force idk m*g
tiny-tim
tiny-tim is offline
#12
Mar11-12, 12:05 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
Force idk m*g
m*g = 0 ?
albarnett17
#13
Mar11-12, 12:11 PM
P: 8
im so confused man heres what i got for
question 1.F(n) = mg
F(n) =(1000)(9.81)
F(n) =9810 N
SF=UF
SF=(0.80)(9810)
Sf=7848
tiny-tim
tiny-tim is offline
#14
Mar11-12, 02:21 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,167
hi albarnett17!
F(n) =(1000)(9.81)
F(n) =9810 N
SF=UF
SF=(0.80)(9810)
Sf=7848
ok so far
(except thequestion says g=10 N/kg, so the friction force is 8000 N)
now use that in F = ma for the x direction
Register to reply
Related Discussions
normal force mastering physics Introductory Physics Homework 1
Physics HW help!? Normal Force between two objects? Introductory Physics Homework 3
Solving for the normal force (Physics assignment) Introductory Physics Homework 11
physics problem: normal force Introductory Physics Homework 3
