Get shocked when wearing the shoes
  • Context: High School
  • Thread starter Thread starter Chuck88
The discussion centers around the phenomenon of experiencing electric shocks while wearing rubber shoes, despite rubber being an insulator. Participants explore potential explanations for this occurrence, including static electricity and contact with live electrical sources.
  • Some participants note that rubber soles are good insulators but question how shocks can still occur when wearing them.
  • One participant suggests that static electricity could build up on the body, remaining until a conductive object is touched, leading to a shock.
  • Another participant seeks clarification on whether the shocks are due to static electricity or contact with a mains power source.
  • A later reply speculates that the likelihood of static discharge may depend on the strength of the power source contacted.
  • One participant proposes that moisture could play a role, as it might allow rubber to conduct electricity, leading to a shock when touching a charged wire.
  • Another humorous suggestion is that a hole in the shoe could also be a reason for the shock.
Participants express uncertainty and seek more details to clarify the situation. There is no consensus on the exact cause of the shocks, with multiple competing explanations being discussed.
The discussion lacks specific details about the conditions under which the shocks occur, such as the charge of the wire and the environmental factors affecting the rubber shoes.
Chuck88
I know that rubber is a type of good insulator of electricity. But the problem is that we will still get shocked when we are wearing the rubber shoes. How does that happen? The rubber shoes should cut off the electric connection between us and the ground?
You're right that the rubber soles act as a good insulator, but rubbing your feet against the ground is not the only source of gaining an electric charge on your body.
And then if you get a charge on yourself, and it can't get out from your feet, it will sit in you until you touch a doorknob.
I am not sure if this is the proper explanation, I am making a guess here. Someone else will probably have a better idea of the cause of this phenomenon.
problem is chuck88 hasnt really given us enough info...
is he referring to the build up of static electricity as you inferred shishkabob?
or is he referring to touching a mains power source etc and still receiving a shock even tho he's wearing rubber shoes ?
details, details, details :)
Dave
Chuck88 said:
I know that rubber is a type of good insulator of electricity. But ... ?
In that light, if you are referring to the shock of static electricity, would you get more of a shock with wearing rubber soles or going barefoot?
for static electricity, wearing the rubber shoes is what is going to build up the huge static charges
D
Dave
good point. I'm personally not sure about either of those.
I would speculate that the probability of static discharge in the second case from a person's body to something else would depend on the strength of the power source that he's touching.
Dave
The details are that I am wearing the shoes and standing on the ground. Suddenly, I saw a pair of bare wires in front of me. I feel quite excited. So I run forward and touch one of the wires. Immediately, I feel shocked.
This is turning out to be more of an investigation! To come to any conclusion, we still need more details(for ex: the charge the wire was carrying,etc
Anyway, now, if your shoes are not charged and you put your shoe on a electric wire, there are just some possible reasons as to why there was a shock:
1) Your shoes had acquired a charge, on contact with the wire, which could mean there might have alredy been some moisture(sweat). Even moist air could make your shoes moist. Water(moisture) molecules would have been absorbed by rubber. And as a result the sole would have conducted electricity, creating an electric shock.
[2)(On a lighter note...) Your shoe may have had a hole!:)]
regards,
math_way
  • · Replies 60 ·
49K
  • · Replies 20 ·
  • · Replies 71 ·
17K
