| New Reply |
Doppler shift of a signal reflected in a mirror moving away from the observer. |
Share Thread | Thread Tools |
| Mar15-12, 09:51 PM | #1 |
I have re-written this as as I accidently deleted my original post. I was wondering if the relativistic Doppler shift of a reflection from a mirror moving away from the observer was the same as the Newtonian equation in the special case that the mirror is orthogonal to the direction of motion.
I referred to equation (13) in this paper http://arxiv.org/ftp/physics/papers/0409/0409014.pdf and set theta to zero for this special case. I now think I have figured out the answer to my own question. The equation I gave in my my first post: [tex] f = f_0 \frac{1-2v/c+v^2/c^2}{1-v^2/c^2} [/tex] Can be re-arranged: [tex] f = f_0 \frac{(1-v/c)(1-v/c)}{(1-v/c)(1+v/c)} [/tex] and simplified: [tex] f = f_0 \frac{(1-v/c)}{(1+v/c)} [/tex] and this is exactly the same as the none relativistic equation for Doppler radar. Length contraction and time dilation is not involved in this special case of reflection in a moving mirror. |
| Mar16-12, 04:15 AM | #2 |
Yes, this is kind of a trivial result though. You can just move to the coordinates of the mirror and argue that because of symmetries (light beam coming in 90 degrees wrt the mirror), outgoing angle must be same as incoming angle.
| Mar16-12, 10:39 AM | #3 |
| Mar17-12, 03:20 PM | #4 |
| New Reply |
| Thread Tools | |
Similar Threads for: Doppler shift of a signal reflected in a mirror moving away from the observer.
| Phase shift of reflected light wave | Classical Physics | 2 | ||
| Doppler Effect, Stationary source moving observer | Introductory Physics Homework | 0 | ||
| Doppler Effect: Moving Observer riding on moving source! With reflection off wall! | Introductory Physics Homework | 3 | ||
| Relativity - Doppler effect in reflection from a moving mirror | Advanced Physics Homework | 0 | ||
| Could moving observer be stationary vs moving and still give Albert the same results | Special & General Relativity | 17 | ||
