Solving Complex Identity: Help with z in Polar and Exponential Form
  • Context: Graduate
  • Thread starter Thread starter theaterfreak
    Complex Identity
The discussion revolves around simplifying the expression |\sqrt{z^2 -1} +z| + |\sqrt{z^2 -1} -z|, particularly focusing on the use of polar and exponential forms of the complex variable z. Participants explore various mathematical approaches and reasoning related to complex numbers and their moduli.
  • One participant attempts to simplify the expression using polar coordinates but encounters difficulties with the square root term.
  • Another suggests using the triangle inequality to derive inequalities related to the expression, but later retracts this approach.
  • A participant proposes that squaring the expression and applying identities on conjugates leads to a simplified form, initially suggesting |\sqrt{z^2 -1} +z| + |\sqrt{z^2 -1} -z| = \sqrt{4z^2-1.
  • Another participant challenges this result, stating they obtained 4z^2-4 instead.
  • A subsequent correction leads to the conclusion that the result is 2z, although this raises questions regarding the presence of the imaginary unit i in the final expression.
  • Participants discuss the nature of the modulus of complex numbers, with one asserting that the modulus should yield a real number, while another clarifies that z is inherently complex.
  • Further elaboration on the calculations is provided, detailing the steps taken to arrive at the conclusion that A=2|z| when z^2 ≥ 1 and A=2 when z^2 < 1.
Participants express differing views on the simplification of the expression, with no consensus reached on the final result or the interpretation of the imaginary component in the context of the modulus.
The discussion includes various mathematical steps and assumptions that are not fully resolved, particularly regarding the treatment of complex numbers and the implications of the modulus operation.
theaterfreak
Hi there.
I need help simplifying the following:
|[itex]\sqrt{z^2 -1}[/itex] +z| + |[itex]\sqrt{z^2 -1}[/itex] -z|
What I did was I rewrote z in polar coordinates, but I ran into some difficulties taking the square root of [itex]r^2(cos2θ-sin2θ)-1[/itex].
I also tried rewritting z in exponential form, but also had problems. Help?
In a first approach to the problem, I'd suggest you try to use the triangle inequality, both for the complete expression and for each of the terms.
You might end up with 2 inequalities in the form: "expression" less or equal to "a + b", and "expression" greater or equal to "a + c", hence "expression" equal to "a"
EDIT: I've tried and that doesn't work, sorry :P
I think I've got it!
If you square the whole expression and use a couple of identities on conjugates you end up with this:
|[itex]\sqrt{z^2 -1}[/itex] +z| + |[itex]\sqrt{z^2 -1}[/itex] -z|= [itex]\sqrt{4z^2-1}[/itex]
I got 4z^2-4 not 4z^2-1
Actually I've just discovered a mistake in my calculation,
The result is: 2z
Oh, ok. I ended up getting 2z as well.
But what doesn't make sense to me is that the original value should have no i (imaginary number) in it since we're taking the modulus. But after simplifying it, we get 2zm which would still have i in it.
I don't see why that doesn't make sense to you.
You can take the modulus of any complex number, and "z" is a complex number, it has an "i" in it: z=x+iy with real part x and imaginary part y.
The modulus of a complex number is its distance to the origin defined as |z|= sqrt(x^2 + y^2) = r
It doen't make sense because the value of the |...| function is a real number, but your result of 2z is a complex number.
You can't just ignore the imaginary part of 2z, without a proper mathmatical reason for doing so.
Oh you're completely right, when I said 2z I meant 2|z| of course
But still I think the solution is not completely right! (Sorry, this is what happens when you try to solve problems quickly on a paper napkin). Let's review all the steps properly:
[tex]A=\left |{\sqrt{z^2-1}+z}\right |+ \left |{\sqrt{z^2-1}-z}\right |[/tex]
[tex]A^2 = \left |{\sqrt{z^2-1}+z}\right |^2 + \left |{\sqrt{z^2-1}-z}\right |^2 + 2\left |{\sqrt{z^2-1}+z}\right |\left |{\sqrt{z^2-1}-z}\right |[/tex]
[tex]A^2 = (\sqrt{z^2-1}+z)\overline{(\sqrt{z^2-1}+z)}+ (\sqrt{z^2-1}-z)\overline{(\sqrt{z^2-1}-z)}+2[/tex]
[tex]A^2= (\sqrt{z^2-1})(\overline{\sqrt{z^2-1}}) + \overline{z}z + \overline{z}\sqrt{z^2-1} + z\overline{\sqrt{z^2-1}}+[/tex]
[tex]+ (\sqrt{z^2-1})(\overline{\sqrt{z^2-1}}) + \overline{z}z - \overline{z}\sqrt{z^2-1} - z\overline{\sqrt{z^2-1}} + 2[/tex]
[tex]A^2 = 2\left |{\sqrt{z^2-1}}\right |^2+2\left |{z}\right |^2 +2[/tex]
[tex]A^2= 2\left |{z^2-1}\right |+2\left |{z^2}\right |+2[/tex]
In conclusion:
[tex]z^2 \geq{1} \rightarrow{A^2=4z^2}\Longrightarrow{A=2\left |{z}\right |}[/tex]
[tex]z^2<1 \rightarrow{A^2=4}\Longrightarrow{A=2}[/tex]
I solved this a little earlier and got the same thing. Thanks for the help!
