New Reply
Panel Structure vs. Solid Rod Structure
Share Thread Thread Tools
Mar18-12, 06:42 AM   #1
Hi Everyone,
I have a question about panel vs. solid rod structures.
Assume a two cubes of equal dimension and weight.
Cube 1 is made of panels, ie. a hollow cube.
Cube 2 is made with solid rod
Material is linear elastic
Which would be stiffer?
I think the panel structure would be the stiffer structure because each panel is supported by another resisting bending. In the rod structure, the rod is only supported at the ends.
Any input would be greatly appreciated
Cheers.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Intel's Haswell to extend battery life, set for Taipei launch
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
Mar18-12, 06:45 AM   #2
Futher to this,
I have forgotten alot from my engineering degree,
How would you work out the deformation of the cube under a verticle load?
I think I can do it for the rod structure but not the panel structure.
Cheers
Mar18-12, 07:03 AM   #3
As with all things, it depends on the exact materiel and construction.
It appears you are describing a monocoque vs spaceframe. The stressed skin has the potential to have much higher stiffness to weight ratio.
If it's just a box, with 12 structural members along the edges, the proper hollow box will be stiffer. This is because a cube would need to be cross braced.
The 'resisting bending' idea is the right concept but wrong direction. For a stiff structure you ideally want no member experiencing any bending, so any 'bending' is eventually taken by a member in tension or compression.
New Reply
Thread Tools
Similar Threads for: Panel Structure vs. Solid Rod Structure
Thread Forum Replies
term structure isomorphic to the usual model/structure of number theory Set Theory, Logic, Probability, Statistics 2
Methods for determination of structure of solid? Atomic, Solid State, Comp. Physics 3
Equation for Solid Planet Structure Astrophysics 5
subtle background structure in deep astronomy photos; CSL-1 cosmic string gravitational lens in Capodimonte Deep Field; Millennium Simulation of evolving cosmic structure; AstroDeep group; Murray mesh; www.Flickr.com evolving cosmic structure; As General Physics 1
structure of solid CO2 Chemistry 4
