New Reply
Projectile launch at elevated height on angle
Share Thread Thread Tools
Mar20-12, 08:28 PM   #1
a baseball player hits a home run. The ball's velocity as it leaves the bat is 45m/s at an angle of 36.9° above the horizontal. At the point of impact with the bat, the ball is 1 m above ground level, and as it clears the fence it is back down to 11 m above ground level. How far from home plate is the fence at this point?
2. Relevant equations
quadratic formula
linear motion equations
basic sin and cos
v=d/t
3. The attempt at a solution
so I started with finding the Vv and the Vh velocties
vh= 45cos6.9= 36.0
Vv= 45sin36.9 = 27.0
then I organized the information I had into two seperate headings
Vv
v1: 27 m/s
v2:*27.4m/s
a: -9.8m/s
t:*5.5
d: -1m
and Vh
vave: 36m/s
t:*5.5
d:*198m
*I found the time using the quadratic formula and came up with 5.5 seconds
* I calculated the total distance the ball travelled using the formula d = v×t and got 198 m
* calulated the v2 for the Vv to be 27.4 m/s using linear motion equation
I'm thinking i need a colum for the fence distance now, however, this part is slightly iffy.
Vh for fence
vave:
t:T
d: 198-D
Vv for fence
v1:
v2:
a:-9.8m/s
t:T
d: -11m
At this point I've hit a dead end.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Mar20-12, 08:39 PM   #2
The question states the ball is at 11m above the ground
So displacement is 10m.
Calculate your time again.(its not right)
After you have time
You will need to multiply it by v(h)*t to get d.(as you already did)
Thats all.thats your answer
I dont understand what (and why)you are doing in the latter part of your post.
Mar21-12, 03:38 PM   #3
Hmm, I always manage to overcomplicate an easy question. thanks, I calculated my time to be 5.1 secs.
Mar21-12, 03:59 PM   #4
Your answer appears correct.
Mar21-12, 04:14 PM   #5
Quote by rahrahrah1 View Post
Always draw a diagram :-)
That shortens the problem in so many ways.
Your time is correct :-)
Now all that is left is to find the distance.
New Reply
Tags
angle launch, distance, projectile, velocity
Thread Tools
Similar Threads for: Projectile launch at elevated height on angle
Thread Forum Replies
Launch angle of projectile with drag Calculus 0
Projectile motion- initial velocity and launch angle Introductory Physics Homework 17
Zero angle launch problem: Find height given inital speed and angle Introductory Physics Homework 1
launch angle of projectile Introductory Physics Homework 12
Very vague question about projectile launch angle Introductory Physics Homework 2
