| New Reply |
effects of soluble impurities boiling and melting points |
Share Thread |
| Mar23-12, 05:53 AM | #1 |
In my textbook, it says that impurities lower the melting point and increase the boiling point.
But is this only true if the boiling point of the impurity is greater than the boiling point of the solvent, and the melting point is greater than of the solvent too? So essentially, if greater bp impurity, boiling point of solution will be increased. if lower bp impurity then the boiling point of solution is decreased. If greater mp impurity, melting point is lowered. if higher melting point impurity then the melting point of the solution will be decreased. then what about alloys? so if i have two metals i want the alloy to have a low melting point, then i put a impurity that has a higher melting point so that the alloy will have a lower melting point? Must the impurity have a smaller percentage in the alloy or the effect will be otherwise where the impurity have a lower melting point which will in turn increase the overal melting point of the alloy? |
| Mar23-12, 08:07 AM | #2 |
Admin
| Mar23-12, 11:43 AM | #3 |
| Mar23-12, 05:57 PM | #4 |
From what I gather, the same rules don't apply to alloys. I don't have much inorganic experience, but from what I gather, the melting point of an alloy is more like the average of the melting points of the constituents. I'll have to look further into it.
| Mar23-12, 06:11 PM | #5 |
Admin
Low melting alloys are usually eutectic mixtures.
| Mar23-12, 10:17 PM | #6 |
| Mar24-12, 03:17 AM | #7 |
http://www.sewanee.edu/chem/Chem&Art...Cox/index.html I wouldn't consider slag a solution, so saying that it had an impurity in it with a lower melting point than 1570° would likely be valid. |
| Mar24-12, 07:46 AM | #8 |
| Mar24-12, 11:27 AM | #9 |
More further reading- It seems alloys are, in fact, considered solutions, not that it changes anything. I would consider pretty much all liquids as solvents, with the exception of molten metal, so water and all organic solvents. I get the feeling you wouldn't deal with liquid salts in these types of problems and you wouldn't deal with liquid nitrogen/other gasses, either. You can do bp elevation with gasses, but it involves pressure, not impurities.
| Mar24-12, 11:58 AM | #10 |
Admin
I put "gas" in quotes as calling something a gas without stating conditions doesn't make much sense. What we consider to be "gases" on liquid giants is usually a liquid, what we consider a liquid (water) is almost always a solid, so the classification just follows are point of view, not the universal reality. Boiling is boiling and it follows the same rules regardless of whether given substance is solid, liquid or gaseous at an arbitrary temperature that we happen to call "room temp". |
| Mar26-12, 03:45 AM | #11 |
| New Reply |
Similar discussions for: effects of soluble impurities boiling and melting points
| Impurities on melting point and boiling point of water | Chemistry | 9 | ||
| What is so magical about the melting and boiling points? | General Physics | 17 | ||
| why impurities decrease melting points. | Chemistry | 1 | ||
| London Forces, current, and boiling and melting points | Chemistry | 6 | ||
| boiling points, melting points and absorbed radiation Q's | Introductory Physics Homework | 0 | ||
