Magnetic flux through coiled wire
The discussion centers on calculating magnetic flux through a circular coil with 25 turns and a radius of 5 cm in Earth's magnetic field of 0.7G. The magnetic flux is determined using the formula Φ = B * N * A * cos(θ), where B is the magnetic field strength, N is the number of turns, A is the area of the coil, and θ is the angle between the magnetic field and the coil's axis. The confusion arises in part (c), where the angle is clarified to be 90 degrees, contrary to the initial assumption of 30 degrees. This highlights the importance of accurately determining the angle for correct flux calculations.
  • Understanding of magnetic flux and its calculation
  • Familiarity with the formula Φ = B * N * A * cos(θ)
  • Knowledge of magnetic field strength in Gauss (G)
  • Basic geometry related to angles and trigonometric functions
  • Study the derivation and application of the magnetic flux formula in different orientations
  • Learn about Faraday's Law of Electromagnetic Induction and its relation to magnetic flux
  • Explore the effects of coil orientation on induced electromotive force (emf)
  • Investigate the properties of magnetic fields and their measurement in Gauss and Tesla
Students in physics, educators teaching electromagnetism, and professionals working with electromagnetic systems will benefit from this discussion.
Dr. Philgood
A circular coil has 25 turns and a radius of 5 cm. It is at the equator, where the earth’s magnetic field is 0.7G north. Find the magnetic flux through the coil when its plane is (a) horizontal, (b) vertical with its axis pointing north, (c) vertical with its axis pointing east, and (d) vertical with its axis making an angle of 30 degrees with north.
\Phi =\int B\cdot da
I understand the magnetic flux part basically is equal to (magnetic field)*(number of turns)*(area)*(cos(θ) in this case equaling (7*10^-5)(25)(Pi*(.05^2))(cosθ) and both A) and B) make sense with cos(90) equaling zero for A) and cos(0) equaling 1 for B). But, C) is where I'm confused.
C) I would assume that with the magnetic field pointing north and the axis pointing east the angle between them should be 90°. Though this is wrong, the correct angle between them is apparently 30°. My question is why is this angle 30° and not 90°?
You don't really multiply by the number of turns to get magnetic flux. But you will need to multiply by the number of turns if you want to find the emf over the whole coil. So I guess it doesn't matter if you do the multiplication now.
About the answer for part c, you're right, the angle is 90 degrees. Maybe you were looking at the answer to part d when you saw 30 degrees?
  • · Replies 21 ·
  • · Replies 21 ·
