The Sun and Hydrogen into Helium Fussion?
The discussion centers on the mechanisms of hydrogen fusion into helium in the Sun, exploring whether the process is primarily driven by high temperatures or quantum tunneling effects. It involves theoretical considerations of nuclear fusion processes, particularly in the context of the Sun's core conditions.
  • Some participants suggest that the Sun's temperature is sufficient for hydrogen nuclei to overcome repulsion and fuse directly, while others argue that quantum tunneling is essential for fusion to occur.
  • One participant notes that both high-energy collisions and quantum tunneling contribute to fusion, with statistical variations in ion velocities allowing for fusion even at lower average temperatures.
  • Another participant mentions that hydrogen first fuses into deuterium in the proton-proton chain reaction, which involves weak interactions and is a rare process, complicating the fusion dynamics.
  • It is stated that the threshold temperature for fusion due to collisions is around 10^8 K, while quantum tunneling allows fusion to occur at approximately 10^7 K, which aligns with the Sun's core temperature.
  • Some participants express that without quantum tunneling, fusion would be virtually nonexistent, highlighting its critical role in the process.
Participants generally agree that both high temperatures and quantum tunneling play roles in hydrogen fusion in the Sun. However, there is no consensus on the relative importance of each mechanism, and the discussion remains unresolved regarding the primary driver of fusion.
The discussion reflects varying interpretations of the conditions necessary for fusion, including the statistical nature of particle energies and the implications of quantum mechanics in nuclear reactions.
parallaxoz
Hi, I'm just after a definitive answer on how Hydrogen fuses into Helium in the Sun?
Some places say the Sun is so hot that they overcome their same charge repulsivness and fuse together while other places say that our sun is not hot enough for that to happen and that they just get close enough to allow them to fuse from Quantum Tunnelling.
It's been the same with the science guys they get on radio stations I've heard some say that our Sun is so hot that they just smash into each other and fuse while other stations they say the Sun simply isn't hot enough and it is Quantum Tunnelling that enables the fussion.
So which is it... is our Sun hot enough for Hydrogen to physically fuse into Helium or is it Quantum Tunnelling that enables the fussion? Obviously the Sun still has to be hot enough to get the Hydrogen close enough for Quantum Tunnelling to happen but is it Quantum Tunnelling that's causing the fussion or is the Sun hot enough that Fussion is happening without any Quantum Tunnelling?
Astronomy news on Phys.org
The truth is that BOTH happen. Statistically some ions should have high enough velocities on impact to overcome their repulsion and fuse, even if the average temperature is well below what should be required. If the ions don't have quite enough energy they can still sometimes tunnel through it due to quantum effects.
Also, hydrogen fuses with itself to form Deuterium in the first part of the proton-proton chain reaction, not helium. This actually relies on the weak interaction as well, making the process even more unlikely to occur since one of the protons must decay into a neutron. If this process wasn't so rare the Sun would have used up its hydrogen long ago. See here for more: http://en.wikipedia.org/wiki/Proton-proton_chain_reaction
As Drakkith suggests, both aspects play a role. The threshold temperature for nuclear fusion due to collisions alone (at the densities approximately that of the sun's core) is about [itex]10^8[/itex] K. QM tunneling decreases this to about [itex]10^7[/itex] K, which is the temperature of the sun's core. If it weren't for tunneling, virtually no fusion reactions would take place.
So the Sun isn't hot enough for fusion to take place if there was not Quantum Tunnelling happening, thank you that's the kind of answer I was looking for.
The average temperature in the core is not, but there will be ions that have a high enough energy to fuse due to the statistical nature of the ion energies. IE some will be more than the average and some will be less.
  • · Replies 42 ·
  • · Replies 32 ·
20K
