| New Reply |
Book on Cable properties |
Share Thread | Thread Tools |
| Apr11-12, 11:40 AM | #1 |
Hey all,
I'm doing an investigate into lock-in amplifiers and am looking for a book, or journal, which has a collection of properties/ characteristics for cables? For example, i'm particularily looking for a reliable source to quote the speed of propagation of a particular co-axial cable! I've had a thought about using the latest edition of the Handbook of chemistry and physics; but am not hopeful it will contain what i need! Hopefully someone has encountered a relevant source Thanks! ~Blind |
| Apr11-12, 11:55 AM | #2 |
Mentor
It would probably be easiest to look at the datasheets for the cables you are interested in. You can find the datasheets at the manufacturer's websites. Belden is a big manufacturer of cables, for example. |
| Apr11-12, 11:57 AM | #3 |
Cheers, I will have a look thank you. I thought i'd just check, Is it acceptable to quote a manufacters reference sheet in a journal? |
| Apr11-12, 11:58 AM | #4 |
Mentor
| Apr11-12, 12:01 PM | #5 |
As for the referencing i'lll investigate further whether or not I can reference it; like you said if it's reliable i don't see why not! If worse comes to worse, ill reference it and hope for the best! Thanks again for the quick reply |
| Apr11-12, 01:00 PM | #6 |
In case of doubt, quote the data sheet with whatever product number or release date the manufacturer put on it.
When the properties change, the manufacturer should either change the product number or re-release the data sheet with a different publication date. |
| New Reply |
| Tags |
| -incable, cable speed, co-axial, lock amplifier, speed of propagation |
| Thread Tools | |
Similar Threads for: Book on Cable properties
| cable length dynamics by adding twists to cable | Classical Physics | 0 | ||
| Medium Voltage Cable Cable sheat integrity test | Electrical Engineering | 2 | ||
| The influence of crossing angle on amplitude in cable to cable coupling | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Cable theory - calculating cable length using graphs | Advanced Physics Homework | 2 | ||
| Tension in a cable car's cable | Introductory Physics Homework | 2 | ||
