Questions about the separating mixture
  • Thread starter Thread starter xyzphineR
    Mixture
The discussion revolves around methods for separating mixtures, specifically focusing on extracting calcium carbonate (CaCO3) from muddy water and separating hexane from copper(II) chloride (CuCl2) in an aqueous solution. The scope includes theoretical and practical approaches to separation techniques.
  • Some participants suggest various methods for separating CaCO3 from muddy water, including using ethylenediamine tetraacetic acid (EDTA) to form a calcium complex at pH=12, which can then be filtered.
  • Others propose washing the muddy water with hot dilute HCl to convert CaCO3 into calcium chloride (CaCl2), followed by precipitation with sodium carbonate to obtain CaCO3.
  • For separating hexane and aqueous copper chloride, one participant notes that the two are immiscible and can be separated using a separating funnel, with the aqueous layer being denser and forming the bottom layer.
  • It is mentioned that boiling the solution can help remove hexane due to its lower boiling point compared to water.
Participants present multiple methods for extracting CaCO3 from muddy water, indicating a lack of consensus on the best approach. There is also agreement on the immiscibility of hexane and aqueous copper chloride, but the details of the separation process are discussed without a definitive conclusion.
Participants express uncertainty about the effectiveness of the proposed methods for obtaining CaCO3 and the specifics of the separation process for hexane and CuCl2. The discussion highlights the need for further clarification on the steps involved in each method.
xyzphineR
As we know, there are several method for separating mixture(separation) for different cases, they are Filtration, Evaporation, Crystallization, Distillation, Fractional distillation, using Separating funnel to separate two immiscible liquids and Paper chromatography to separate small amount of substances in a mixture. And now I have two questions, I hope somebody can answer me :smile:
1. Except we clip the CaCO3 directly after the filtration, how can separate and get the CaCO3 when the solution was like this : A mud-water with CaCO3 inside.
2.How can we separate this mixture?
Hexane + CuCl2 (and also the water of course)
Apologize for my poor english :biggrin:
Chemistry news on Phys.org
Well, your first question may be solved by various ways, I am not sure which will fit your needs. However, you can use ethylenediamine tetraacetic acid (EDTA) to form a calcium complex at pH=12, and filter it to remove from muddy water. Calcium ion can be released by mixing this solution with a metal ion which will give a more stable complex with EDTA, say, copper ions.
Hexane and aqueous copper chloride solution are not miscible with each other, just using a separating funnel will work; I think the aqueous solution has a greater density than hexane, so it will form the bottom layer. Removing it from hexane layer will give you a slightly hexane-involved aqueous solution, the hexane can be removed by boiling the solution for a little time, as its boiling point is lower than that of water.
thanks for your answer my man :biggrin: but i still have the main problem for the first question, which is "obtain / get the CaCO3 from the muddy water", if i have not make a mistake from your answer, using ethylenediamine tetraacetic acid will release Calcium ion right? but then all i need is CaCO3 :o)
maybe you can tell me another way to get CaCO3 from the muddy water^^
Maybe you can try this one: Wash the muddy water sample with hot dilute HCl solution, the calcium carbonate will be converted into calcium chloride, CaCl2, and by filtering you will remove this solution from muddy water. Then you require that the calcium ions be in the form of carbonate, add sodium carbonate until all calcium has been precipitated, and filtering this one again will give you the desired product.
thanks thanks =DDDDD
14K
  • · Replies 29 ·
  • · Replies 28 ·
