What is the linear acceleration of the .67kg mass?
The discussion focuses on calculating the linear acceleration of a 0.67 kg mass connected to a pulley system with a 1.3 kg pulley and a 25 N force applied. The tension in the rope differs on both sides of the pulley due to the unequal forces acting on it. The moment of inertia for the pulley is calculated as I = 0.037 kg·m², using the formula for a solid disk. To find the linear acceleration, the participant needs to apply Newton's second law (F=ma) and consider the forces acting on both the mass and the pulley.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of moment of inertia for solid disks (I = 1/2 mr²)
  • Familiarity with tension in pulley systems
  • Basic concepts of linear acceleration
  • Calculate the tension in the rope on both sides of the pulley using the forces involved.
  • Apply Newton's second law to derive the linear acceleration of the 0.67 kg mass.
  • Explore the dynamics of pulley systems and how forces interact within them.
  • Review examples of similar problems involving pulleys and linear acceleration.
Students studying physics, particularly those focusing on mechanics and dynamics, as well as educators seeking to explain concepts related to pulleys and linear acceleration.
Up_Creek
Ok
here's the question;
"You pull downward with a force of 25N on a rope that passes over a disk-shaped pulley of mass 1.3 kg and radius 0.075m. The other end of the rope is attached to a .67-kg mass. (a) Us the tension in the rope the same on both sides of the pulley? If not, which side has the largest tension? (b) Find the tension in the rope on both sides of the pulley.
(c) Find the linear acceleration of the .67kg mass.
Ok, we're using g=10 m/s so the pulley is 13N and the mass is 6.7N.
I've gotten all the forces drawn in but I'm kind of sketchy about how to get the answer. I know I need to combine several equations to find t, tension.
So in total I have this attached image here.
The steps I know I need are as follows
1.) Draw a picture
2.) isolate bodies
3.) draw in forces
4.) resolve forces
I know i'll need to use F=ma. I'm assuming that hopefully I can re-work that so I get a=F/m? Also, as (c) was the only question assigned, do I need to do (a) and (b) to get (c)?
a rough outline of what I think
Since the 25N force is greater than the 6.7N mass, the pulley will accelerate counter-clockwise (or 'out' according to the right hand rule, not sure why that's important, or even if it is) So i'll take counter-clockwise to be positive. Tension must be down, since rope cannot push. Obviously the tension is different on both sides of the pulley, or they wouldn't word the question like that, and the force on the 25N side would create more tension on that side too, right?
Anyway, I need to find the linear acceleration of the 6.7N mass. Linear acceleration I think would be acceleration in the y direction, right?
Jordan Veale
It has come to my attention that i'll also need moment of inertia, I
the pulley would be a solid disk, so I = 1/2 mr^2
So
I = .5(13N)(.075m^2)
I = .037
that's just taking into account the weight of the pulley alone. Or do I have to add the weight of the mass and the 25N force too?
  • · Replies 20 ·
  • · Replies 31 ·
  • · Replies 18 ·
  • · Replies 17 ·
