Vector Problems: Finding Parallel and Perpendicular Vectors
  • Thread starter Thread starter formulajoe
    Vector
The discussion revolves around vector problems involving finding parallel and perpendicular vectors in three-dimensional space. Participants are exploring the conditions under which vectors can be parallel to the y-axis and the requirements for vectors to be mutually perpendicular.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the conditions for a vector to be parallel to the y-axis, questioning the implications for its x and z components. There are attempts to set up equations based on the dot product to find values for a, b, and c in the second problem, with some participants expressing uncertainty about their algebraic manipulations.
There is an ongoing examination of the algebra involved in the problems, with some participants suggesting that the original poster may need to clarify their understanding of the requirements for the vectors. Multiple interpretations of the problems are being explored, and some participants express doubt about the correctness of the answers provided in the textbook.
Participants are working under the assumption that the textbook answers may be incorrect, and there is a focus on verifying the calculations and understanding the vector relationships involved.
formulajoe
ive been struggling with these for an hour and a half.
they arent hard, i just can't seem to make them work.
the first one is:
A = (5,3,2)
B = (-1,4,6)
C = (8,2,0)
im using this format (x,y,z)
aA+bB+ C = a vector parallel to the y-axis.
so, that means i need to find a vector with only z components right?
well, the answers out of the back of the book are a = -12/7 and b = -4/7.
these don't work out.
heres the second one
A = (a,1,4)
B = (3,b,-6)
C = (5,-2,c)
Im supposed to find a,b, and c so that all three vectors are perpendicular to each other.
that means i should use the dot product with A and B, A and C, and B and C and set the dot product equal to zero for all three. So I did this, and i got answers for a, b and c but they don't work out when i check them.
if a vector is parallel to y axis, that's means the vector is pointing at y direction... so what will the x and z component of this vector be? after you have the x and z component.. what you ganna to is write down the equation for x&z component... then you will have 2 equation, with 2 unkn..for the 2nd problem, your method is completely fine... check your algebra again
okay, i tried this
5a -b + 8 = 1
3a + 4b +2 = 0
this leaves a 1 in x, and a 0 in y
i solved it this way, and got close to the right answer. am i on the right track?
okay, this way should be right
5a - b = -8
2a + 6b = 0
a = -1.5
b = .5
maybe the answers in the back of the book are wrong?
Hi Formulajoe,
Did you consider the questions of Vincenchan ?
If a vector should be parallel to the y axis, what requirements can you put on the x, y, z coördinates. I'm sure you can work out the algebra to calculate the solutions, but I've got the impression you're a bit in the vague as to what you need to calculate...
Greetz,
Leo
Hi formulajoe,
you're right. Your solution is correct. Maybe the answers in your book are wrong.
If a = -12/7 and b = -4/7 then the z-component of aA+bB+C is:
(-12/7)(2)-(4/7)(6)+0=-48/7
So it is not parallel to the y-axis.
Check if you read the question correctly. If you did, then the books answer if wrong.
