The Constant of Integration
  • Context: Undergrad
  • Thread starter Thread starter fizzacist
    Constant Integration
The discussion revolves around the interpretation of the constant of integration when solving a differential equation related to physics. Participants explore the differences between their own solutions and a provided rubric from an AP physics exam, focusing on the mathematical treatment of the constant of integration.
  • One participant presents a differential equation and their method of solving it, expressing confusion over the treatment of the constant of integration in comparison to an exam rubric.
  • Another participant questions the difference between the two forms of the constant of integration, suggesting that the use of the letter C may be causing confusion.
  • A third participant proposes redefining the constant of integration to align with the rubric's expression, indicating that constants are arbitrary and can be manipulated without affecting the solution.
  • A later reply indicates understanding of the explanation provided, suggesting that the confusion has been resolved for that participant.
Participants do not reach a consensus on the interpretation of the constant of integration initially, but later exchanges suggest that at least one participant finds clarity in the proposed explanation.
There is an unresolved ambiguity regarding the definitions and roles of constants in integration, as well as the implications of using different symbols for constants.
fizzacist
While taking an AP physics practice exam, I encountered a difference in the way I solve a differential equation and the way the exam's rubric solves it.
The equation is as follows:
[itex]\frac{dv}{dt}[/itex] = [itex]\frac{F-KV}{m}[/itex]
My solution:
[itex]\int[/itex][itex]\frac{dv}{F-KV}[/itex] = [itex]\int[/itex] [itex]\frac{dt}{m}[/itex]
u = F-KV
[itex]\frac{du}{-K}[/itex] = dv
[itex]\frac{-1}{K}[/itex] [itex]\int[/itex][itex]\frac{1}{u}[/itex]du = [itex]\int[/itex][itex]\frac{dt}{m}[/itex]
Integrate that to find
ln|F-KV|+C = -K[itex]\frac{t}{m}[/itex]
But before I go any further, the 1993 Exam's Rubric shows that by integrating [itex]\int[/itex][itex]\frac{dv}{F-KV}[/itex] should yield ln|F-KV|-lnC
To me, this makes no sense. The constant of integration should be ln|u| + C, not ln|u|-lnC
Here's what I'm talking about:
http://imgur.com/c83p1
I've also attached the '93's rubric to this post. The problem I'm referring to is problem #2.
Can any of the math/physics gurus out there help me out? :P
Thanks
What's the difference? :confused:
Maybe you're confused because you're using C for two different things. Try comparing
  • ln|u| + D, and
  • ln|u|-lnC
Call your constant of integration K (remember K is completely arbitrary). Now define another constant C by K = -lnC. This gives the formula in the book. Since C is also completely arbitrary, it doesn't matter.
Ahh. Got it. :P
  • · Replies 27 ·
  • · Replies 19 ·
