New Reply
Washing machine motor soap extruder
Share Thread
Apr18-12, 07:50 AM   #1
Hello
I am trying to start a small home business making soap. I am on a really tight budget and also very new to the extrusion process.
While I may be extruding soap, I understand that the process is very similar to plastic extrusion.
I want to extrude soap bars using a machine similar to the soap extruder on this website
http://soaptec.biz/products_dp_finesextruder.html
However I am trying to make this as cheaply as possible.
I plan on buying a screw and barrel and then fabricating the rest of the machine myself.
I am thinking of using a washing machine motor to drive the screw.
Could you please advise me on the viability of this?
What size screw and barrel would I need to order from the supplier? I was told that a 30mm or 40mm screw would be best, a 100mm screw would require too much power and would be too expensive.
Would a washing machine motor be suitable?
The manufacturer of the screw and barrel asked me what power motor would be used and what are the gear ratios. What should I tell him? I have not told him that I plan to use a machine motor
Any advice would be greatly appreciated
Thank you
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Apr18-12, 09:12 AM   #2
Tell him the power of the motor and what rpm you plan on running the screw at...
New Reply
Similar discussions for: Washing machine motor soap extruder
Thread Forum Replies
What to do with a washing machine motor? General Engineering 15
Hand Washing Question: Glycerin Soap Biology 2
artificial gravity in a washing machine Introductory Physics Homework 5
[SOLVED] Washing Machine revolution Introductory Physics Homework 7
Can u wash sneakers in a washing machine?? General Discussion 23
