How Do You Convert GeV/c to m/s for Particle Velocities?
  • Context: Undergrad
  • Thread starter Thread starter iamBevan
    Convert
The discussion revolves around converting particle momentum expressed in GeV/c to velocity in m/s. Participants explore the relationships between energy, momentum, and velocity, particularly in the context of relativistic physics.
  • One participant attempts to calculate velocity by dividing momentum (in GeV/c) by the mass of the particle, leading to unexpected results.
  • Another participant suggests using the energy-momentum relation \( E^2=(mc^2)^2+(pc)^2 \) to find the total energy and subsequently the velocity.
  • A participant expresses confusion over obtaining a velocity greater than the speed of light when using a specific mass and momentum value.
  • There is a repeated question regarding the validity of converting momentum directly using the conversion factor \( 1 \text{ GeV/c} = 5.36 \times 10^{-19} \text{ kg-m/s} \) and dividing by the particle's mass.
  • A later reply clarifies that momentum is not simply mass times velocity in relativistic contexts, introducing the correct relativistic momentum equation.
Participants do not reach a consensus on the correct method for converting momentum to velocity, with multiple approaches and interpretations presented. Confusion persists regarding the application of relativistic equations.
Participants express uncertainty regarding the assumptions behind their calculations, particularly in relation to the definitions of mass and the applicability of classical versus relativistic momentum equations.
iamBevan
As the title said :)
I'm trying to find the velocity of a particle with a momentum of between 23 and 150 GeV/c. I found that 1 GeV/c = 5.36 x 10^-19 kg-m/s, and tried to divide by the mass of the particle - this just game me values between 7m/s and some crazy numbers.
What am I doing wrong :(
One way is to use the relation
[tex]E^2=\left(mc^2 \right)^2+\left(pc \right)^2[/tex]
where [itex]pc[/itex] is 23 to 150 GeV (momentum in energy units), and [itex]mc^2[/itex] is the particle's rest mass (proton is 0.938 GeV). Then use [itex]\beta =pc/E[/itex] to get [itex]\beta[/itex], and [itex]v=\beta c[/itex].
Thank you for your help Bob S - I still can't manage to get the answer though.
When I set m to 5.5208x10^27kg, and p to 25GeV/c I end up getting a value that is faster than c when I solve for v. Can anyone help with this?
If 1 GeV/c = 5.36 x 10-19 kg-m/s though, why can't I do 25(5.36x10^-19)/particle's mass?
Using the relation
where [itex]pc=[/itex] 50 GeV and [itex]mc^2=[/itex] 0.938 GeV, E = 50.008798 GeV.
So β= 50/ 50.008798= 0.99982 and βc = 2.9974 x 1010 cm/sec
Because p ≠ mv, if you're using the particle's "rest mass" in kg. The correct equation is
$$p = \frac{mv}{\sqrt{1 - v^2/c^2}}$$
  • · Replies 0 ·
  • · Replies 75 ·
  • · Replies 16 ·
