Whats fire made of? What element atoms are it.?
  • Context: High School
  • Thread starter Thread starter aditya23456
    Atoms Element Fire
The discussion revolves around the composition and characteristics of fire, specifically focusing on what elements or atoms constitute a flame and the physical principles governing its behavior. Participants explore various aspects of fire, including its state of matter, the role of combustion products, and the nature of light emitted by flames.
  • Some participants suggest that the peak of a flame points upwards due to buoyancy and gravity.
  • Others argue that a flame is a state of matter known as plasma.
  • It is proposed that the flame consists of vapors from the burning material and oxygen from the air, but there is debate about the presence of combustion products.
  • Some participants assert that fire is light emitted by excited atoms during combustion, while others challenge this characterization, emphasizing the role of radiation and hot gases.
  • There is a discussion about flames that emit light outside the visible spectrum, with examples of materials that burn into UV light.
  • Concerns are raised regarding the definition of fire versus flame, with some participants noting that soot and combustion products play a significant role in the appearance of flames.
  • Participants mention specific examples, such as magnesium and methanol, which can burn with UV emissions, and discuss the visibility of flames from different fuels.
Participants do not reach a consensus on the composition of flames or the definitions of fire and flame. Multiple competing views remain regarding the nature of combustion products and the characteristics of flames.
There are unresolved questions about the definitions of fire and flame, the role of combustion products, and the conditions under which flames may emit light outside the visible spectrum.
aditya23456
why does peak of fire of a matchstick face upwards ie away from ground.why is it not effected by gravity,is there any reason other than pressure considerations.
It is affected by gravity which is why it is pointing up. Buoyancy being the key word.
The flame is a state of matter known as plasma.
Someone correct me if I'm wrong, but the flame is not made up of any particularly special atoms or substance. It is simply a regular substance, such as air, that has been heated to the point that it releases light.
You are right about "nothing special", but it is not "just air". Think combustion products.
A large part of a flame is carbon dioxide (or if the fire is "starved of oxygen" carbon monoxide). And it is affected by gravity but hot gasses are less dense than the colder air around them.
It's made of the vapors of the burning object plus oxygen from the air.
So there is no combustion products in the flame? If so, where does the energy heating the flame comes from?
fire is light emitted by the excited atoms of the material when excited to the point of combustion
Heat = light = magnetic radiation just on a diffrent frequency
No. Fire is not just a light.
what you "see" and "feel" as fire is simply radiation visible light and infrared
Aside from smoke and other random particles but the "flame" is nothing more then light from atoms that have been excited to the point where they begin an exothermic reaction with the air around them
Fire is the rapid oxidation of a material in the exothermic chemical process of combustion, releasing heat, light, and various reaction products.[1] Slower oxidative processes like rusting or digestion are not included by this definition.
The flame is the visible portion of the fire and consists of glowing hot gases. If hot enough, the gases may become ionized to produce plasma.[2] Depending on the substances alight, and any impurities outside, the color of the flame and the fire's intensity will be different.
http://www.cbsnews.com/8301-504784_162-20106378-10391705.html
can a flame be in such a way that it gives out only light of frequencies other than visible light..I meant flame exists but its hardly visible to human eye
yes there are several materials that burn off into UV instead of visible light
What about hot soot that is no longer reacting due to the lack of oxidant, but still emitting the IR/light just because of its high temperature? It doesn't fit this definition.
Even assuming your original answer was technically correct, it addressed only what the flame is, while the question is about fire. You listed definitions of fire and flame, so you know these are two different things, but you still insist your partial answer is the correct one?
like what?
Note how hydrogen flame from the main engines is almost invisible, especially in comparison with solid propellant SRBs.
Lsos didn't say "just air", he said "such as air" which allows other things.
Antiphon said "vapors of the burning object" which Merriam-Webster defines as "diffused matter (as smoke or fog) suspended floating in the air and impairing its transparency"
pure magnesium burns into some uv light along with visible light
and i believe so does methanol
Wild-land firefighters occasionally come across this phenomenon where its "on fire" but burning so cold that the flame is not visible to the naked eye
If it is burning cold, then it should radiate even less in UV than normal fire. As for Mg, you said yourself its flame is visible, so these examples are invalid.
Flame from most organic fuels, like wood, candle, gasoline, etc., is primarily glowing soot. Products of combustion are translucent gases, meaning they aren't going to emit much via black-body. Soot, having very high absorption coefficient is also very good at emitting radiation.
I'm not sure about natural gas burners, to be honest. But if a gas burns clean, the flame is not going to be very visible. Case in point,
Enthalpy of formation of H20 is -242kJ/mol. That's enough to heat water vapor to at most 7k K. (Realistically, significantly less.) This is still well within visible band. The reason you don't see the flame is because it also happens to be very close to the minimum in absorption spectrum for H2O, so the emission intensity is very low.
  • · Replies 74 ·
  • · Replies 17 ·
