New Reply
Miscellaneous questions on operators
Share Thread
May8-12, 12:41 PM   #1
Hey guys, I am wondering if the following relationships hold for all operators A, regardless of whether they are linear or non-linear.
A-1A = AA-1 = I
[A,B] = AB - BA
A|an> = λn|an>, where n ranges from 1 to N, and N is the dimension of the vector space which has an orthogonal basis |an>.
Just one other question. Which is the more general definition of the adjoint (hermitian conjugate) A† of an operator A: (v, Au) = (A†v, u) or A† = (A*)T?
I think it's the first one. The second one is a special case of the first which is valid if the vectors v and u are matrices. Your thoughts?
Let's see if you can make a dumbass like me learn some maths!
PhysOrg.com science news on PhysOrg.com
>> Leading 3-D printer firms to merge in $403M deal (Update)
>> LA to give every student an iPad; $30M order
>> CIA faulted for choosing Amazon over IBM on cloud contract
May26-12, 05:56 AM   #2
The first is def'n of inverse, which doesn't always exist.
The second is definition of commutator over the ring of operators.
The third is definition of eigenvalue and eigenfunction, and an assumption that there is a finite eigenbasis of the space. Note it is possible for some of the eigenvalues to be identical.
The fourth, your first expression is def'n of adjoint (the other of a mirrored pair, mirrored to other side of the inner product). But to say it's the transpose, you have to clarify the def'n of transpose. If A is a matrix, you're probably fine. If it's not, and say for example it's the derivative operator, then what do you mean by transpose. Also, if you're space is not flat, in other words, if there is some nontrivial metric, then the adjoint may get more complicated. See for example
wikipedia.org/wiki/Transpose#Transpose_of_linear_maps
and the issue of a metric tensor.
A course in Functional Analysis would treat most of this quantum mechanical material with some rigor.
New Reply
Similar discussions for: Miscellaneous questions on operators
Thread Forum Replies
Some "simple?" questions on miscellaneous things? General Physics 2
Miscellaneous Geometrical Optics Questions Introductory Physics Homework 4
miscellaneous courses to take? Academic Guidance 11
some questions about reducible matrices and operators Linear & Abstract Algebra 2
Miscellaneous facts General Discussion 14
