Thermodynamics calculating Pressure temp and Volume?
The discussion focuses on calculating the final temperature (T2) and pressure (P2) in a thermodynamic system where 1440 kJ/kg of heat is added to a gas with a specific heat capacity of 0.72 kJ/kgK and a heat capacity ratio (gamma) of 1.4. Given the initial conditions of mass (0.00058 kg), initial volume (V1 = 0.000005 m³), initial temperature (T1 = 753 K), and initial pressure (P1 = 25.12 Bar), the equations p2 = p1 * (v1/v2)^1.4 and p1 * v1 / T1 = p2 * v2 / T2 are utilized. The process is identified as a constant volume process, allowing for the calculation of T2 using the relationship Q = ΔT = Cv * ΔT.
  • Understanding of thermodynamic principles, specifically the first law of thermodynamics.
  • Familiarity with specific heat capacity and its role in heat transfer calculations.
  • Knowledge of the ideal gas law and its application in pressure and volume calculations.
  • Ability to manipulate and solve equations involving thermodynamic variables.
  • Study the derivation and application of the first law of thermodynamics in closed systems.
  • Learn about constant volume processes and their implications in thermodynamic calculations.
  • Explore the concept of specific heat capacities for different substances and their significance.
  • Investigate the relationship between pressure, volume, and temperature in ideal gases using the ideal gas law.
Students and professionals in engineering, physics, or any field involving thermodynamics, particularly those working on heat transfer and gas behavior under varying conditions.
mm391
Can someone explain how I would calculate T2 and P2 knowing that 1440kJ/kg of heat was added, Specific Heat Capacity is 0.72KJ/KgK and gamma = [itex]\mu1.4[/itex] and mass = 0.00058kg?
V1 = 0.000005m^3 V2 = V1
T1 = 753K T2 = ?
P1 = 25.12 Bar P2 = ?
p2=p1*(v1/v2)^1.4
p1*v1/T1=p2*v2/T2
Looks like you have a constant volume process. Therefore Work done = 0, Q= ΔT=Cv*ΔT. You know Q, Cv, and T1 so you can find T2.
