| New Reply |
Two collars and a fixed shaft, required friction? |
Share Thread | Thread Tools |
| May10-12, 04:41 PM | #1 |
Two collars A and B can slide on vertical rods. Collar A and collar B are connected by a cord that passes over a fixed shaft at C. the static friction coefficient of any two contact surfaces is 0.2. the weight of collar B is 10 lb, neglect collar A's weight, determine the range of force F required to maintain the equilibrium. 1. The problem statement, all variables and given/known data i1261.photobucket.com/albums/ii597/JacobtFry/statics8.png 2. Relevant equations 3. The attempt at a solution 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| May12-12, 11:05 AM | #2 |
You have to show your attempt before we can help you - forum rules.
| New Reply |
| Tags |
| engineering, friction, homework help, statics |
| Thread Tools | |
Similar Threads for: Two collars and a fixed shaft, required friction?
| Wheel attached to a fixed shaft | Introductory Physics Homework | 1 | ||
| Help calculating power required to drive shaft | Introductory Physics Homework | 4 | ||
| Force required to turn shaft | Classical Physics | 2 | ||
| Force required to turn shaft | Mechanical Engineering | 4 | ||
| Material required for shaft. | Mechanical Engineering | 6 | ||
