| New Reply |
did the heaviest elements come from other galaxys |
Share Thread | Thread Tools |
| May12-12, 04:00 AM | #1 |
did the heavier elements come from different galaxys? im a gcse student who is in a bit of a debate with my teacher :)
| May12-12, 04:20 AM | #2 |
oh and all i have got is that "Brian Cox said it once i think." i am going to need a little more than that :)
| May12-12, 05:05 AM | #3 |
Because of the great distances between galaxies, only high-speed "cosmic rays" reach us from outside the Milky Way, though the Milky Way itself probably formed by the merger of smaller galaxies. http://en.wikipedia.org/wiki/Stellar_nucleosynthesis http://en.wikipedia.org/wiki/Supernova_nucleosynthesis |
| May12-12, 05:16 AM | #4 |
Given that the universe is extremely big and atoms are extremely small, some of every element in our galaxy came from Andromeda. Probably some of every element in your body came from Andromeda. What is your question exactly?
| May13-12, 09:30 AM | #5 |
Recognitions:
| May13-12, 10:43 AM | #6 |
| May13-12, 11:46 AM | #7 |
Do we have reason to believe any supernova explosion remnants in Andromedia could not or would not likely have reached our galaxy?? After reading somebdy found one of the RNA proteins in meteor debris, I'd not rule much of anything out!! |
| May13-12, 12:22 PM | #8 |
| May13-12, 01:21 PM | #9 |
Recognitions:
| May14-12, 07:06 AM | #10 |
Recognitions:
The heavier elements in our galaxy came from supernovae within our galaxy. And likewise for other galaxies.
| May14-12, 07:20 PM | #11 |
My reasoning is as follows:
(1) Galaxies are filled with hot, ionized gas, with temperatures in the keV range, A proton with a temperature of 1 keV has an average velocity of about 400 km/sec. (2) A galaxy like Andromeda has a mass on the order of 10^12 Msun. At a distance of 10 kpc, the escape velocity is about 900 km/sec. Further out, the escape velocity is lower. (3) Therefore, the Maxwellian tail of the hot gas has enough velocity to escape the galaxy. This is similar to the Earth's atmosphere where the particles in the tail of the Maxwellian distribution evaporate over time. (4) A particle moving at 900 km/sec will cross the 800 kpc separating the Milky Way from Andromeda in about 0.8 gigayears. While this is a long time, the galaxies have been associated for much longer than this. (5) In addition, we see a constant stream of cosmic rays arriving at the Earth, with energies as high as 10^21 eV. These particles are relativistic, hence travelling at basically the speed of light, so there is no doubt they will escape, and they will cross intergalactic distances much faster. These are known to consist of elements at least as high as iron. Some of them almost certainly come from other galaxies. Therefore there should be a steady stream of atoms arriving from Andromeda, and other galaxies as well. I'm sure it is a tiny fraction of the atoms associated with the Milky Way, but it is still a huge number of atoms. For those of you who disagree, are you saying that none of the perhaps 10^68 baryons in the Milky Way came from Andromeda? Or do you disagree with the analysis above? |
| May14-12, 08:29 PM | #12 |
Recognitions:
| May15-12, 02:21 AM | #13 |
The heaviest elements come from supernovae, in any galaxy.
Is the Milky Way static? I'm pretty sure it has merged with other galaxies in the past, taking in all of its elements, heavy or not. So if you are asking did ALL the heaviest elements come from another galaxy, then I would say NO! If on the other hand you are asking if some COULD have come from another galaxy, then I would say why the heck not!?! |
| May15-12, 02:23 AM | #14 |
| May15-12, 03:39 AM | #15 |
Mentor
| New Reply |
| Thread Tools | |
Similar Threads for: did the heaviest elements come from other galaxys
| What's Your Heaviest Day? | General Discussion | 9 | ||
| What are the heaviest and lightest particles? | General Physics | 26 | ||
| Heaviest Lifting Aircraft? | Mechanical Engineering | 13 | ||
| The Center of Galaxys | Astrophysics | 16 | ||
| [SOLVED] Some questions about galaxys | General Astronomy | 9 | ||
