Temperature increase due to increase of resistance
The discussion focuses on calculating the temperature increase required to raise the resistance of a copper wire by 14%. The temperature coefficient of copper is established as 0.004 per degree Celsius. The correct formula to use is R = Ro(1 + αt), where R is the resistance at temperature t, Ro is the original resistance, and α is the temperature coefficient. The initial calculation of a 35°C increase was incorrect due to a misunderstanding of the temperature coefficient's application.
  • Understanding of electrical resistance and its dependence on temperature
  • Familiarity with the temperature coefficient of materials, specifically copper
  • Knowledge of the formula R = Ro(1 + αt)
  • Basic algebra for manipulating equations
  • Study the derivation and applications of the resistance-temperature relationship in conductors
  • Learn about the temperature coefficients of other materials for comparative analysis
  • Explore practical applications of resistance changes in electrical engineering
  • Investigate the effects of temperature on semiconductor materials
Students in physics or electrical engineering, educators teaching resistance concepts, and professionals working with conductive materials in temperature-sensitive applications.
pokie_panda
To what value would you have to raise the temperature of a copper wire (originally at 20 deg/C ) to increase its resistance by 14 % ?
temp. coeffic of copper = 0.004
delta T = 0.14/0.004
delta T = 35 deg/C
why is this incorrect.
You need to realize that the temp coefficient (0.004/C) means that the resistance of copper Changes by 0.004 x resistance at 0C for each degree change in temperature
So R = Ro(1 + αt) where R = resistance at tC and α = temp coeff of resistance
Have you met this equation?
correction made
Yeh I have seen the equation somewhere in the textbook thanks for help
  • · Replies 21 ·
