New Reply
Mixing of Two Gases
Share Thread Thread Tools
May28-12, 07:19 PM   #1
Mixing of Two Gases
Hi
I'm working on a project where I have a two flow controller controlling the volumetric flow rate (in the order of 0.01-0.1ml/min) of two different gases. The gases are mixed together and I'm wondering if there's a way to figure out the exiting volumetric flow rate of the combined flow and what kind of information is required? Is just adding the two volumetric flow rate (as if the gases are a liquid) a good approximation?
Thanks
PhysOrg.com
PhysOrg
engineering news on PhysOrg.com
>> Army ground combat systems adopts tool for choosing future warfighting vehicles
>> Company pioneering new types of material for 3-D printer 'ink'
>> Student-built innovations to help improve and save lives
Jun6-12, 10:51 AM   #2
What are the gases? Assuming ideality, then yes, that's exactly what you would want to do.
However, in reality, there might be a small change in volume from mixing.
Jun6-12, 11:31 AM   #3
Quote by pa5tabear View Post
I'm doing N2 and air for now but CO2 or H2 may also be involved instead of one of N2 or air. So ideally, one can add the volume flow rates together? I'm a bit confused on why since gases are compressible.
Thanks
Jun7-12, 03:54 PM   #4
Mixing of Two Gases
Quote by Red_CCF View Post
Thanks
Okay good point. I wasn't thinking very well. You will have to take into account the conditions at each point (temp, pressure). I was thinking that you could treat them ideally, and if the conditions are the same, then you could expect the volumes to be additive.
I'd expect all those gases mentioned to be near ideal, so using the ideal gas law should be fairly accurate.
Jun14-12, 12:24 AM   #5
I'm still puzzled with this approximation. By conservation of mass:
mdot1 + mdot2 = mdottotal and if the volume flow rates are additive and ignoring compressibility effects (as my flow rates are quite low)
I get ρ1*Vdot1 + ρ2*Vdot2 = ρtot*Vtot and if Vtot = Vdot1+Vdot2 this implies that all the density values are equal? I'm not sure how even assuming that the gases are ideal and have constant temperature and pressure will allow this approximation to be valid?
Any help is appreciated
Thanks
New Reply
Thread Tools
Similar Threads for: Mixing of Two Gases
Thread Forum Replies
Entropy of Mixing for Two Ideal Gases at Different Temperatures Advanced Physics Homework 2
Design of a mixing box of different gases Engineering Systems & Design 1
Mixing gases to achieve desired ppm Materials & Chemical Engineering 2
Mixing Gases Advanced Physics Homework 0
mixing of gases Introductory Physics Homework 2
