New Reply
Don't get the conduction band in solid
Share Thread Thread Tools
May29-12, 02:50 PM   #1
I was reading about electronic band structure in wiki and I didn't understand why the conduction bands are necessary for flowing current in a material. If all the atoms in a solid shares valence band and all its eletrons, then these electrons may travel through the solid. I didn't get why the electrons in the valence bands can't freely travel within solid and so make current.
Thanks for explanation!
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> Study provides better understanding of water's freezing behavior at nanoscale
>> Iron-platinum alloys could be new-generation hard drives
>> Promising doped zirconia
May29-12, 03:18 PM   #2
Because the valence band is symmetric in momentum. That is, in a semiconductor with a filled valence band for each electron with momentum +k there is another electron with momentum -k, so there is no net current. Even if one applies an electric field to bias the current in a certain direction, this basic momentum balancing effect is still present.
Once you get some electrons in the conduction band and have a partially filled band, then the application of an electric field can break this symmetry.
May30-12, 08:27 AM   #3
Thank you very much for your help. But there is a thing. Why can't we break this symmetry also in a valence band ? There's no different between them, right? Why can't an electric field break symmetri also in the valence band?
May30-12, 12:35 PM   #4
Because the valence band is full, which means that for every available momentum k, there is an electron with momentum k and -k. That's the definition of a full band. If you apply an electric field, that doesn't change which momenta are available, it just lowers the energies of momenta which point in the opposite direction. But if the band is full then this doesn't change the momenta of any electrons because there are no available states for electrons to shift around.
Now if you remove some electrons from the valence band, then when the E field is electrons will move into the empty states that go opposite the E field, providing a net current. When this happens in the valence band this is referred to as hole current. In the conduction band it is electron current.
Jun1-12, 02:53 PM   #5
Thanks. Can you please recommend me any material, webside or text where I can read about it more?
Thank you very much.
Jun1-12, 10:08 PM   #6
Hi,
you might be interested in this series of lectures by keio university
http://www.youtube.com/watch?v=aOVSOIAtjoA
yinx
Jun2-12, 01:51 PM   #7
I'm not sure, but he's describing in the video that an electron in valence band cannot move because it's traped. If the electron gets to conduction band then it can flow because it's actually got from the trap.
I'm really not sure of this assertion. I think it's not so simple. I have thought electrons in a valence band can move throught a solid, can't they?
New Reply
Tags
band, conduction band, current, solid, valence band
Thread Tools
Similar Threads for: Don't get the conduction band in solid
Thread Forum Replies
Valance and conduction band in solid. Atomic, Solid State, Comp. Physics 4
Energy given off Photons/Heat from Conduction Band (Conduct Electron) to Valance band Atomic, Solid State, Comp. Physics 3
Valance band to Conduction Band (Valance Electron), Energy Band Gap Levels Advanced Physics Homework 0
E-K Diagrams, valence band, conduction band... Introductory Physics Homework 14
What is conduction band? Chemistry 4
