Fields of a moving point charge with constant velocity.
The discussion focuses on the electromagnetic fields generated by a moving point charge, specifically utilizing the Lienard-Wiechert potentials. A point charge moving along the x-axis with constant velocity v yields an electric field expressed as \vec E = \frac{q}{4\pi \varepsilon_0} \frac{\gamma}{r'^3} \left( \vec r - \vec v t\right) . This contrasts with Griffith's result, which incorporates angular dependence and is given by \vec E =\frac{q}{4\pi \varepsilon_0} \frac{1 - v^2/c^2}{(1 - v^2 \sin^2 \theta/c^2)^{3/2}} \frac{\hat R}{R^2} . The discrepancy arises from the differing transformations of coordinates parallel and perpendicular to the motion, highlighting the necessity of considering Lorentz transformations in electromagnetic theory.
  • Understanding of Lienard-Wiechert potentials
  • Familiarity with electromagnetic field equations
  • Knowledge of Lorentz transformations
  • Basic concepts of special relativity
  • Study the derivation of Lienard-Wiechert potentials in detail
  • Explore Griffith's treatment of moving point charges in "Introduction to Electrodynamics"
  • Learn about the transformation properties of electric fields under Lorentz transformations
  • Investigate the implications of angular dependence in electromagnetic fields
Physicists, electrical engineers, and students of electromagnetism seeking to deepen their understanding of the behavior of electric fields from moving charges and the application of special relativity in electromagnetic theory.
center o bass
The fields of a moving point charge can be constructed from the Lienard-Wiechert potentials. However could one not just consider a point charge at rest in a frame S' and transform the relevant quantities such as [tex]A^{\mu}[/tex] back to S and then deduce the fields from here. Should not the the two results agree? I considered the problem of a point charge moving along the x-axis with constant velocity v and deduced that
[tex]\vec E = \frac{q}{4\pi \varepsilon_0} \frac{\gamma}{r'^3} \left( \vec r - \vec v t\right)[/tex]
where i just transformed the potential from the charge in S'
[tex]\phi' = \frac{q}{4\pi \varepsilon_0} \frac{1}{r'}, \ \ \ r' = \sqrt{x'^2 + y'^2 + z'^2}.[/tex]
However the result from Griffith's s. 439 eqn (10.68) is that
[tex]\vec E =\frac{q}{4\pi \varepsilon_0} \frac{1 - v^2/c^2}{(1 - v^2 \sin^2 \theta/c^2)^{3/2}} \frac{\hat R}{R^2}, \ \ \ \vec R = \vec r - \vec v t[/tex]
where [tex]\theta[/tex] is the angle between [tex]\vec R[/tex] and [tex]\vec v[/tex].
I do not see how these two results can agree, especially not with the angle.
Take a look at a book like Jackson, which derives the field of a moving point charge both ways and shows that the two results agree.
The angular dependence comes from the fact that E and E transform differently (different factor of γ). Deriving it from φ the way you did, notice that x and z also transform differently. Whichever coordinate is parallel to the motion, it picks up a γ, while the one perpendicular to the motion does not.
  • · Replies 30 ·
  • · Replies 24 ·
  • · Replies 18 ·
