How long to melt the ice(heat, heat transfer, latent heat)
The discussion revolves around a problem involving heat transfer and phase change, specifically focusing on the melting of ice. The original poster presents a scenario where a 0.25 kg piece of ice is heated by an electric heater, with a graph illustrating the temperature change over time. The question seeks to determine the additional time required to melt the ice after an initial 150 seconds of heating.
  • The original poster attempts to calculate the energy required to heat the ice and then to melt it, using specific heat capacity and latent heat equations. Some participants question the accuracy of the temperature change during the initial heating period, noting that the temperature rises from -30°C to -10°C rather than the assumed 30°C. Others discuss the implications of this correction on the calculations and methodology used.
Participants are actively engaging with the original poster's calculations, providing feedback on the assumptions made regarding temperature changes. There is acknowledgment of the original poster's understanding of the stages involved in the problem, but also a recognition that the initial temperature change needs to be corrected. The discussion is ongoing, with participants clarifying concepts and questioning the original setup.
The problem is constrained by the assumption of no energy loss to the surroundings and the need to accurately interpret the graph provided. The original poster's understanding of temperature variables and their implications in the calculations is also under scrutiny.
supernova1203
The graph is in the attachment! ( don't have to download to view the file)
49a) A 0.25 kg piece of ice is warmed by an electric heater and the following graph of temperature is produced. Assume that there has been no loss of energy to surroundings.
How much additional time after 150s will be required to melt all of the ice, assuming the power on the heater is constant?
Q=m1c1Δt (c is specific heat capacity and Δt is change in temperature)
Q=mLf
Another way to word the question 49a would be to ask ‘ How long does it take for ice to get from -10 degrees to 0 degrees
Q=mLf is for the amount of energy it takes to melt the ice.Q=m1c1Δt is for the amount of energy it takes to heat the ice.Q=m1c1Δt
=(0.25)(2.1 X 103)(t2-t1)
=(0.25)(2.1 X 103)(0-(-30) <------the ice is initially at -30 as you can see on the graph.(graph is in attachment, and can be viewed without downloading)
=(0.25)(2.1 X 103)(0+30)
Q=15750 J
This is the amount of energy required to heat the ice.
P = W/Δt (Δt is now for time)since W = ΔE = Q P= 15750 J/150s (this 150s was given, as you can see on graph)
P = 105 W ( this remains constant as the question states)Q=mLf is for the amount of energy it takes to melt the ice.
=(0.25)(3.3 X 105)
Q = 82500 J (it takes this much energy to melt the ice)
P=Q/ΔtQ/P = Δt
82500/105 = Δt785.7 s =ΔtThe question asks how much additional time it will take AFTER 150s, so we subtract 150 from 785.7s
785.7-150
=635.7s It will take an additional 635.7s to melt the ice.
or 635.7/60
= 10.5 mins or it will take 10.5 mins to melt the ice.Does this look right? If not can you show me how to get the correct solution? Or better yet, if i have the incorrect solution, get the right solution and show it to me and i will figure out on my own on how to get the right solution.
(graph is in the attachment, as always you don't have to download to view file :) )
For the time interval shown on the graph (150s), the ice temperature change is not 30C. It starts at -30C and rises to -10C over the 150s. This will change your heater power calculation and subsequent values.
ahh... i see
So...everything else looks good? the procedure and the steps i have and the method i used to get the solution is fine?
Also the reason i put it to 0 degrees instead of -10 is because i always understood t2 was usually the melting point
supernova1203 said:
ahh... i see
Your methodology looks okay; you seem to understand the required stages for solution.
A variable is what you say it is :smile: When analyses become more complex than "generic examples" you have to be flexible in your variable assignments :smile:
