| New Reply |
Really Basic Question regarding Continuity |
Share Thread | Thread Tools |
| Jun11-12, 05:57 PM | #1 |
Hello,
I was reading through some lecture notes on Single-Variable Calculus, and the teacher gave this definition of continuity: "A function f is called continuous at a point p if a value f(p) can be found such that f(x) → f(p) for x → p. A function f is called continuous on [a, b] if it is continuous for every point x in the interval [a, b]." Now, I thought this meant the function actually had to be defined at p, but the teacher says that the function 1/log(|x|) is continuous at 0. Of course, log(|x|) isn't defined at 0. So, I have to ask the question, Does a function have to be defined at a point to be continuous at that point? Thanks, Mathguy PS: I have found other definitions that say f(p) must exist. |
| Jun11-12, 06:10 PM | #2 |
Your teacher has some weird terminology. Usually, the function must always be defined at p in order for the function to be continuous.
Of course, often the function is not defined at p, but a value of f(p) can be given. Strictly speaking, we don't talk about a continuous function then. Such a thing is usually called a removable singularity. The function that is continuous is actually the unique extension of f at p. |
| Jun11-12, 09:42 PM | #3 |
What micromass said. It is unusual for a definition of continuity.
Basically, it is the usual definition plus a stipulation that you can fill in gaps in the domain anywhere the limit exists but at which the function is not naturally defined by the formula. A more trivial example would be x^2/x. It is somewhat ambiguous whether 0 is in the domain of this function or not. Personally, I would say that the reasonable answer is that this is the same as the function x which is defined everywhere. So basically, your prof is saying the same sort of thing. If there is a defect in the formula that leaves out points, then we should automatically fill them in if possible. |
| Jun11-12, 10:27 PM | #4 |
Alrighty, thanks!
| Jun12-12, 10:16 AM | #5 |
According to you your teacher
| New Reply |
| Thread Tools | |
Similar Threads for: Really Basic Question regarding Continuity
| basic question about basic concept: proportionality | General Physics | 1 | ||
| cauchy sequences and continuity versus uniform continuity | Calculus & Beyond Homework | 1 | ||
| Basic Proof Related to Continuity | Calculus & Beyond Homework | 2 | ||
| Basic limits and continuity help | Calculus & Beyond Homework | 6 | ||
| continuity question. | Calculus & Beyond Homework | 1 | ||
