Finding the Optimal Time to Launch a Mission to Mars
  • Context: Graduate
  • Thread starter Thread starter xaz
    Launch Mars Time
The optimal time to launch a mission to Mars is determined by calculating the Earth-Sun-Mars angle and the synodic period of Mars. The next opposition of Mars occurs on April 8, 2014, and the synodic period is 780 days. To achieve a launch angle of 44.4°, a spacecraft should ideally launch approximately 20.5 days before opposition, around March 19, 2014. However, due to Mars' eccentric orbit and varying orbital velocity, precise calculations are necessary to determine the exact launch date and angle.
  • Understanding of Kepler's laws of planetary motion
  • Familiarity with orbital mechanics and transfer orbits
  • Knowledge of synodic periods and their calculations
  • Basic trigonometry for angle calculations
  • Research Kepler's laws and their application in space missions
  • Learn about calculating synodic periods for celestial bodies
  • Explore methods for determining transfer orbits in interplanetary travel
  • Investigate Mars' orbital characteristics and eccentricity effects
Aerospace engineers, astrophysicists, and mission planners involved in interplanetary travel and orbital mechanics will benefit from this discussion.
xaz
Recently for a project I have been trying to figure out the correct time to launch a spaceship and have it successfully reach Mars. This is what I've managed so far
Because of Earth's orbit around the sun a ship would have a transfer orbit that looks like this
Distance from starting point to ending point= 1+1.523 =2.523 AU (addition of orbits)
Semi major axis of transit orbit= 2.523/2=1.261
Kepler's third law [T]^{2} = [a]^{3}[/itex], therefore T= \sqrt{1.261^{3}} = 1.417454 years
This is a time for a fall orbit so time for a trip=1.417454/2= 0.70873 years
location of Mars at time of launch= 360* (0.70873/1.88)= 135.555^{o}, so something like this
Now the angle between Earth Sun and Mars = 180-135.6= 44.4^{o}
To find when this angle occurs I was thinking of using c^{2}=a^{2}+b^{2}-2ab CosC, where a is the distance from Earth to the sun, b is the distance from Mars to the Sun, c is the distance between the two planets and C is the Earth Sun Mars angle. For a and b I used r=periapsis*{1+e}/{1+e cos(theta)} , I know this equation isn't perfect as it assumes Mars and Earth orbit at the same velocity and start at the same point but I'm going to adjust it later. Now my problem is I've been having trouble getting an equation for c, can anyone help me with that, or alternately does anyone know how I could find when this particular Earth Sun Mars angle is going to occur.
Thanks for any help in advance
Astronomy news on Phys.org
If you are looking for a rough date, you can do this: First you determine the date for an opposition of Mars (the next one will occur on Apr 8, 2014.)
Then you find the synodic period (opposition to opposition) of Mars by
[tex]P = \frac{1}{\frac{1}{P_E}- \frac{1}{P_M}}[/tex]
this gives you a value of 780 days. From this you find that the Earth-Sun-Mars angle changes at a rate of 2.167 degrees per day. If you take this and divide it into the needed Earth-Sun-Mars angle, you get how many days before opposition you have to launch. For 44.4° this is 20.5 days or ~Mar. 19, 2014. (Though actually, I get an answer of ~60.5° and a launch date of Mar 11, 2014)
However, this is only approximate. Unfortunately, Mars has a fairly eccentric orbit, and its orbital velocity varies by a quite a bit. How many days it takes to cover a given number of degrees of its orbit depends on what part of its orbit it's in at the time. For example, because of this, the period between oppositions can vary by several weeks.
So to get an accurate answer, you need to know what point of its orbit Mars will be in at arrival and then compute how many degrees of its orbit it will travel during the transfer orbit.
  • · Replies 98 ·
12K
  • · Replies 21 ·
  • · Replies 18 ·
10K
  • · Replies 86 ·
9K
  • · Replies 16 ·
16K
