| New Reply |
Apostol's Calculus Vol.1 6.26 #1 |
Share Thread |
| Jul11-12, 07:29 PM | #1 |
Let f(x)=∫1x (logt)/(t+1)dt if x>0. Compute f(x) + f(1/x). As a check, you should obtain f(2) + f(1/2) = 1/2(log2)2. 3. The attempt at a solution I have tried various calculation that I know, such as integration by parts, but after ten hours with pieces of papers, I still have no idea on how to lead to the answer: 1/2(logx)2. It'd be appreciated if you gave me some hints! |
| Jul11-12, 09:12 PM | #2 |
Mentor
| Jul11-12, 11:42 PM | #3 |
Let me assume your log is ln. Well, directly integrating the original integral goes nowhere because it can't be represented by elementary functions.
This problem can be done by first finding f'(x)+f'(1/x) using Fundamental Theorem of Calculus [tex] f(x)=\frac{d}{dx}\int _{a}^{x}f(\tau)d\tau [/tex] f'(1/x) needs to be handled with care. use u substitution, then use chain rule for differentiation. After all that, you will be integrating a much nicer function that leads to 0.5ln2(x) |
| Jul12-12, 02:07 AM | #4 |
hmm, I am afraid that Apostol wants us to solve it by applying integral and differential properties of logarithm function instead of FTC as I suggested in post #3.
| Jul12-12, 02:37 AM | #5 |
If you brute force the integral (as I've tried in Mathematica), you get the PolyLog special function coming into play, as well as pi. In fact before I got Mathematica to simplify it, the answer it gave me for f(2) + f(1/2) looks like this:
[tex]\frac{\pi^{2}}{6} - Log[\frac{3}{2}] Log[2] + Log[2] Log[3] + PolyLog[2, -2] + PolyLog[2, -1/2][/tex] which of course simplifies to [itex]\frac{1}{2}Log[2]^{2}[/itex] but it is not intuitive at all. So I'm sure Apostol wants you to employ those tricks. |
| Jul12-12, 09:06 AM | #6 |
klondike, I got it, thanks! I've realized that forgetting to multiply by -1/x2 led me to the wrong way, and made me believe that FTC won't make it. Now I can have sweet dreams.
![]() SammyS, Apostol's Calculus has answers to numerical exercises in the back. |
| Jul13-12, 01:27 PM | #7 |
Mentor
Using substitution to find an alternate integral representation for f(1/x) can lead to an integral representation of f(x)+f(1/x) which can be integrated using elementary functions... And, yes, it does give the result that [itex]\displaystyle f(x) + f\left(\frac{1}{x}\right)=\frac{\left(\ln(x)\right)^2}{2}[/itex][itex]\frac{}{}[/itex] |
| Jul13-12, 02:25 PM | #8 |
[itex]\displaystyle f\left(\frac{1}{x}\right) = \int_1^{1/x} \frac{\ln{t}}{t+1} dt = \ln{x} \int_1^x \frac{dt}{t+x} - \int_1^x \frac{\ln{t}}{t+x}dt[/itex]and adding this to f(x) I get [itex]\displaystyle f(x) + f\left(\frac{1}{x}\right) = \ln(x)\int_1^x \frac{dt}{t+x} + (x-1)\int_1^x \frac{\ln{t}}{(t+1)(t+x)}dt[/itex]which I am not sure can be converted into an elementary function... |
| Jul13-12, 06:48 PM | #9 |
Recognitions:
| Jul13-12, 07:22 PM | #10 |
[itex]\displaystyle f(x) = \int_1^x \frac{\ln{t}}{t+1} dt = \int_1^{1/x} \frac{-\ln{y}}{\frac{1}{y}+1} \cdot \frac{-1}{y^2} dy = \int_1^{1/x} \frac{\ln{y}}{y(y+1)} dy = - f\left(\frac{1}{x}\right) + \int_1^{1/x} \frac{\ln{y}}{y} dy[/itex]which gives the answer. Wow, I learned a lot from this problem. Thanks, everyone! |
| Jul13-12, 08:59 PM | #11 |
Mentor
Anyway, here's what I did with this. [itex]\displaystyle f\left(\frac{1}{x}\right) = \int_1^{1/x} \frac{\ln(t)}{t+1} dt [/itex] Let u = 1/t , then t = 1/u, and [itex]\displaystyle dt=-\frac{1}{u^2}du\,.[/itex] Furthermore, when t = 1/x, u = x . Therefore, [itex]\displaystyle f\left(\frac{1}{x}\right) = -\int_1^{x} \frac{\ln(1/u)}{u^2(1/u+1)} du [/itex] ln(1/u) = -ln(u) . u is a "dummy" variable, so change it to t, allowing you to combine the integrals. |
| Jul13-12, 09:18 PM | #12 |
Recognitions:
| Jul13-12, 09:33 PM | #13 |
Mentor
Well, I started my previous post more than 3 hours ago, then came back to finish it. I didn't want to kill it after composing part of it, so I didn't look for any more recent posts. At any rate, the approach is a little different. I suggested working with f(1/x), you suggested working with f(x). My approach didn't use partial fractions. |
| Jul13-12, 10:28 PM | #14 |
Recognitions:
| New Reply |
| Tags |
| calculus |
Similar discussions for: Apostol's Calculus Vol.1 6.26 #1
| Should I buy Apostol's Calculus? | Science Textbook Discussion | 6 | ||
| Need some advice regarding apostol calculus volume 1 | Calculus | 2 | ||
| Calculus: Apostol or Spivak? | Science Textbook Discussion | 15 | ||
| what are the pre-requisites for Apostol calculus vol. 2? | Science Textbook Discussion | 2 | ||
| Apostol's Calculus | Calculus | 3 | ||
