| New Reply |
I need a help designing Motor Driver Circuit |
Share Thread | Thread Tools |
| Jul19-12, 12:18 AM | #1 |
I'm designing a driver circuit for a 12V DC motor (Power Window). I'm using an L293D motor driver chip.
According to the datasheet the chip can withstand a supply voltage Vs up to 36V. I'm only using a 9V battery. The circuit and the motor are working well. However, after a few seconds the L293D chip would overheat. If I stop it, it will not work again until it cools down, and if I leave it I'm afraid the chip would be burned I'm sure there is nothing wrong with my connections because I've redone them many times. Do you know the reason or the solution to the problem?! You can get the proper chip connection from here |
| Jul19-12, 01:42 AM | #2 |
Are your inputs static or are they switching at some frequency?
| Jul19-12, 03:26 AM | #3 |
![]() You're way underpowered i think. Did you heed the heatsink instructions on pages 10, 11 & 12 of datasheet? http://www.ti.com/lit/ds/symlink/l293d.pdf |
| Jul19-12, 05:14 AM | #4 |
The driver IC that you are using can handle up to 1A, if the IC is over heating so it may be due to that the motor is consuming higher current.
Try to measure the current, and if it was greater than 1A and if your connection are all correct, use smaller motor. Regards, Hisham |
| Jul19-12, 06:41 AM | #5 |
| Jul19-12, 06:53 AM | #6 |
You can view it from here http://www.cytron.com.my/viewProduct...29%20-%20Right And you're probably right about the current .. unfortunately, I have to use this motor because a smaller motor will not perform the function required |
| Jul19-12, 06:58 AM | #7 |
So you have to use another driver which can support higher current, or you can make your own driver with transistors that can handle higher current. |
| Jul19-12, 06:59 AM | #8 |
| Jul19-12, 07:11 AM | #9 |
I don't have time now, read how this driver work http://www.sparkfun.com/datasheets/R...8_H_Bridge.pdf
You have to make the same concept, but with larger transistors. And tonight i will send you explanation also. |
| Jul19-12, 08:47 AM | #10 |
| Jul19-12, 03:31 PM | #11 |
Dc motors drivers consist of transistors that are connected in H-bridge configuration.
See the attached picture to have a look on how H-bridge looks like. When transistors T1 and T3 are on and transistors T2 and T4 are off, current will flow from VCC2 through T1, to T3 then to ground, and the motor will rotate on some direction lets say to the anti clock wise. When transistors T2 and T4 are on and transistors T1 and T3 are off, current will flow from VCC2 through T2, to T4 then to ground, and the motor will rotate on the opposite direction. So you can drive your motor using this configuration but you have to choose the correct transistor that can handle the current that is required by the motor in your case 7A. Google for H-bridge Dc motor controller, you will find a lot of schematics, and you can share your design for any information needed. Or try to find a supplier where you can buy H-bridge that can handle this current. Hope this helps, Hisham |
| New Reply |
| Tags |
| circuit, driver, heat, l293d, motor |
| Thread Tools | |
Similar Threads for: I need a help designing Motor Driver Circuit
| Constructing a DC motor driver | General Physics | 8 | ||
| Designing Motor Driver Circuit | Electrical Engineering | 3 | ||
| Motor Driver | General Engineering | 2 | ||
| Motor Driver circuit | Electrical Engineering | 1 | ||
| motor driver booster | Electrical Engineering | 8 | ||
