How High Will a Golf Ball Bounce After Falling Down a 3m Staircase?
  • Thread starter Thread starter Parzival
The golf ball, when dropped from a height of 3.00 m onto a staircase, will bounce back to its original height of 3.00 m after each elastic collision with the stairs. The analysis assumes that all collisions are perfectly elastic and neglects air resistance. Regardless of the number of steps, whether 15 steps of 20 cm or 30 steps of 10 cm, the final bounce height remains 3.00 m due to the conservation of mechanical energy.
  • Understanding of elastic collisions in physics
  • Knowledge of gravitational potential energy (mgh)
  • Familiarity with the conservation of mechanical energy
  • Basic principles of kinematics
  • Study the principles of elastic collisions in detail
  • Explore gravitational potential energy calculations
  • Learn about the effects of air resistance on bouncing objects
  • Investigate the kinematics of objects in free fall
Students studying physics, educators teaching mechanics, and anyone interested in the dynamics of bouncing objects.
Parzival
A golf ball bounces down a flight of steel stairs, striking each stair on the way down. The ball starts at the top step with a vertical velocity component of zero. If all the collisions with the stairs are elastic, and if the vertical height of the staircase is 3.00 m, determine the bounce height when the ball reaches the bottom of the stairs. Neglect air resistance.
Momentum before collision = momentum after collision
I tried setting up equations, but only got as far as mgh = 1/2mv^2 because of conservation of ME.
You need to approximate here:
Although the golf ball is creeping forward down the stair case, we have to assume the motion approximates vertical motion - you might imagine you are actually dropping the ball onto a platform that becomes progressively lower between each bounce - 1 step down, 2 steps down, 3 steps down etc.
Although the Earth will be accelerating up while the Golf ball accelerates down [and vice verca] the ratio of masses between the Earth and a golf ball means we can ignore the motion of the earth.
When two masses have an elastic, head on collision, the two bodies move away from the centre of mass after collision at the same speed as they approach the centre of mass before collision.
If we ignore the speed of the Earth {see above} this means that if the Golf ball approaches a step at 1.5 m/s, it leaves the step at 1.5 m/s.
Now, if the Golf Ball falls from the highest level, to the first step, it will gain a speed V, under the influence of gravity, as it falls. Since it bounces back at speed V, it will regain its original height while the effects of gravity stop it prior to the next plunge.
It now falls to the second step and bounces back to the original height. Then the 3rd, the 4th, the 5th etc.
How many steps are there.
If each step is 20 cm high [meaning 15 steps to cover the 3.00 m height, the bounces total
20 + 40 + 60 + 80 + ... + 280 + 300 = 2400cm
However if the steps were only 10 cm high, meaning 30 of them in all, the bounce total would be
10 + 20 + 30 + ... + 280 + 290 + 300 = 4650 cm
SO how many steps are there?
Perhaps the question is just after the final bounce height - which is 300 cm regardless of the number of stairs.
9K
