Problem with finding time from projectile motion problem
The problem involves a projectile launched from a cliff at an angle of 37° with an initial speed of 65 m/s. The objective is to determine the time it takes for the projectile to hit the ground, taking into account the height of the cliff, which is 125 meters.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to apply the kinematic equation for vertical motion but questions whether they are using the correct equation and parameters. Some participants suggest breaking down the initial velocity into its components and question the role of the angle in the calculations.
Participants are actively discussing the correct approach to the problem, with some suggesting the need to consider the vertical component of the initial velocity. There is recognition of a potential misunderstanding regarding the use of trigonometric functions and the implications of the angle on the calculations. The original poster has acknowledged a mistake related to calculator settings affecting their results.
There is an emphasis on ensuring the correct use of angles in calculations, particularly the distinction between degrees and radians, which has been identified as a source of confusion. Participants are encouraged to clarify their understanding of the equations governing projectile motion.
coneheadceo
A projectile is fired from a cliff 125m off the ground at 37° from the horizontal at 65 m/s. How long will it take to hit the ground?
y= yo+(Vyo)(t) - 1/2(g)(t^2)
quadratic formula
substituting in equation...
(-125m)= 0 + (65m/s)(t) - 1/2 (9.8 m/s^2)(t^2)
(4.9 m/s^2)(t^2)- 65 m/s (t) -125m =0
rewrite in quadratic to solve for t
t=((65 m/s) +/- √((65)^2-4(4.9 m/s^2)(125)))/ 2(4.9m.s^2)
t = 10.9 s
answer in back of book is 10.4 s
not sure if using proper equation or totally missing something.
welcome to pf!
hi coneheadceo! welcome to pf! :smile:
erm :redface:
where's the 37° ? :wink:
Heyas Tim,
The 37° is the angle the projectile is fired at from the top of the cliff with respect to the horizontal.
yes i know! :smile:
but it's not in your equations! :wink:
So would I go for something like this...
To find the Vyo = (65 m/s)Sin 37 and Vxo = (65 m/s)Cos 37 instead of just using 65 m/s?
so then...
(-125m)= 0 + [(65m/s)sin 37](t) - 1/2 (9.8 m/s^2)(t^2) for the y component of time
and
(-125m)= 0 + [(65m/s)cos 37](t) - 1/2 (9.8 m/s^2)(t^2) for the x component of time?
Then do I just add them after using the quadratic for each?
yes :smile:
so then...
yes :smile:
and
erm :redface:
what is the acceleration in the x direction? :wink:
hmm … draw a diagram, and then think
what do the x and y equations each tell you?​
So should my acceleration be (+) and I would end up with an equation...
(-125m)= 0 + [(65m/s)cos 37](t) +1/2 (9.8 m/s^2)(t^2)
I drew a diagram and am at a loss for what each equation "should" be telling me.
As tiny-tim already said, what's the acceleration in x direction? g acts vertically downwards, is their any component of g in the x direction?
Show us the diagram you have drawn.
This is wrong. The time it takes for the projectile to land depends only in the y direction. Therefore, your equation should reflect only the motion of the projectile in the y direction. your velocity should therefore be 65sin(37°)m/s instead of simply 65m/s as you have here. This is the mistake which accounts for the error in your answer.
I worked it out using 65sin(37°)m/s as the velocity and got 10.38s for the time.
I'll have to recheck my math. Thank you for the correction swill777!
Nope... banging my head against the wall here... I'm missing something with my math.
HALLELUJAH!
Nevermind now people. Go back to drinking coffee as I needed a whole ton to realize...
my calculator was set for answers in RAD instead of DEG
http://roflrazzi.files.wordpress.com/2010/04/129164952429291808.jpg
Thank you for your patience and help!
coneheadceo said:
HALLELUJAH!
It is always a good idea to enter sin(30) into your calculator before each set of calculations just to check it gives you 0.5 - indicating if it is actually set to degrees.
coneheadceo said:
HALLELUJAH!
Yup, the degree/radian mix up will get ya. I've had to make it a habit to check my setting every time I deal with trig. Glad you got the right answer, though!
  • · Replies 18 ·
