Where Are Electron-Hole Pairs Created in Solar Cells?
Electron-hole pairs in solar cells are generated throughout the semiconductor material, but only those formed in the depleted region contribute to current generation. The built-in electric field in the pn-junction drives the separation of these pairs, with electrons moving towards the n-type side and holes towards the p-type side. This separation creates an excess charge that results in current flow when the terminals are connected. Understanding this mechanism is crucial for optimizing solar cell efficiency.
  • Understanding of pn-junction theory
  • Familiarity with semiconductor physics
  • Knowledge of electric fields in semiconductors
  • Basic principles of solar cell operation
  • Research the role of the built-in electric field in solar cells
  • Explore the effects of irradiance on electron-hole pair generation
  • Learn about charge carrier dynamics in semiconductor materials
  • Investigate methods to enhance solar cell efficiency
Physicists, electrical engineers, and anyone interested in the fundamental principles of solar cell operation and optimization.
properphysicist
When power is generated in a solar cell, it is because of irradiance of radiation on a pn-junction. But in which part of the junction are the electron-hole pairs created? Is it just the depleted region or are they also created in the n- and p-type semiconductors?
An engineer's response would be for me to consider a current source in parallel with a diode but I need a physicists response. What the heck is going on in a solar cell?
I'd be grateful for any help, thanks.
The electron-hole pairs can be generated anywhere in a semiconductor, but they would recombine at once and nothing would happen unless they were formed in the depleted region and sucked away at opposite directions by the "built-in" electric field there. You know that positive charges are accumulated at the n type side near the junction and negative charges at the p type side. So the electron-hole pair will be separated, the electron moving into the n side and the hole moving into the p side. This results excess charge on both sides, and connecting the terminals you get current.
ehild
Thank-you echild. That answer is quite helpful.
  • · Replies 18 ·
