New Reply
Deducing Maclaurin series converges from Leibniz formula
Share Thread Thread Tools
Jul29-12, 03:25 AM   #1
Given f(x) = xe-x2 I can differentiate once and use Leibniz to show that for n greater than 1
f(n) = -2nf(n-2) - 2xf(n-1)
I want to show that the Maclaurin series for f(x) converges for all x.
At x = 0, the above Leibniz formula becomes f(n) = -2nf(n-2)
I know that f(0) = zero so this implies that even terms of Maclaurin series are zero, whilst
f(1)(0) = 1, f(3)(0) = -6*1 = -6, f(5)(0) = -10*-6*1 = 60 and so on.
I assume that to show convergence, I need to find a formula for the nth term of the Maclaurin series, then use the ratio test to show that terms are decreasing. I can see the pattern (the derivative increases by a factor of 2(2n + 1) each time) but am unsure how to express this in a formula. Perhaps using factorials?
Thanks for any help.
PhysOrg.com
PhysOrg
mathematics news on PhysOrg.com
>> Mathematicians analyze social divisions using cell phone data
>> Can math models of gaming strategies be used to detect terrorism networks?
>> Mathematician proves there are infinitely many pairs of prime numbers less than 70 million units apart
Jul29-12, 03:35 AM   #2
Hey sr3056 and welcome to the forums.
One suggestion is to use the Mclaurin series expansion for e^(-x^2) and then multiply all terms by x. So you start by expanding e^(-x) and then replace every x by an x^2, and multiply each term by x.
The above should give you a series expansion which should allow you to do a further test for convergence.
Jul29-12, 12:13 PM   #3
Thanks. Is there no way of proving convergence from the Leibniz formula though?
Jul29-12, 07:13 PM   #4
If you get a series that is the correct definition, then you should be able to do what you said (i.e. the ratio test), so as long as you get the correct series expansion, it will be OK.
Both series expansions should be equal though and testing this will test whether your above approach is the same as the one I discussed above.
New Reply
Thread Tools
Similar Threads for: Deducing Maclaurin series converges from Leibniz formula
Thread Forum Replies
Leibniz Formula/Fundamental Theorem of Calculus Calculus & Beyond Homework 2
Law Of Sines, deducing addition formula Precalculus Mathematics Homework 3
Leibniz criterion and Maclaurin approximations Calculus & Beyond Homework 4
What's the Reasoning behind the Maclaurin Series? How did Maclaurin discover it? Calculus 3
Expanding Leibniz formula for derivatives with Mathematica Math & Science Software 0
