Which FTIR preparation for polystyrene?
  • Thread starter Thread starter ecnerwalc3321
    Ftir Preparation
For analyzing polystyrene using FTIR, the recommended sample preparation involves creating a KBr disk for solid samples. Liquid preparations using solvents like toluene are unsuitable due to structural similarities with polystyrene. A small ball mill, specifically the Wig-L-Bug, is effective for grinding polystyrene into fine particles for this preparation method. This approach ensures accurate trace element analysis without interference from similar compounds.
  • Understanding of FTIR (Fourier Transform Infrared Spectroscopy) principles
  • Familiarity with KBr disk preparation techniques
  • Knowledge of sample grinding methods, specifically using a Wig-L-Bug
  • Awareness of solvent interactions, particularly with aromatic compounds
  • Research KBr disk preparation for FTIR analysis
  • Learn about the operation and maintenance of the Wig-L-Bug ball mill
  • Explore alternative grinding techniques for polymer samples
  • Investigate the effects of solvent choice on FTIR results
Chemists, materials scientists, and laboratory technicians involved in polymer analysis and FTIR spectroscopy will benefit from this discussion.
ecnerwalc3321
If I have some polystyrene and want to analyze it using FTIR for trace elements, what type of sample preparation should I look into? If I were to use a liquid sample preparation, I wouldn't be able to use say, toluene, because the two structures are similar, correct (aromatic)? On the other hand, if I were to use a solid sample preparation by making the KBr disk, could I just have a chunk of polystyrene sandwiched in the middle (how do you grind up small amounts of polystyrene)?
Chemistry news on Phys.org
We use a small ball mill called a Wig-L-Bug.
  • · Replies 19 ·
11K
  • · Replies 43 ·
  • · Replies 21 ·
