Probability density function,normalize and expectation values
The discussion revolves around the normalization of a probability density function related to the quantum state of an electron in a hydrogen atom. The original poster presents a function that describes the probability density and seeks to derive the expectation value of potential energy for the electron in the n-th quantum state.
  • Participants discuss the normalization procedure, questioning the integration limits and the nature of the probability density function. There are attempts to clarify the relationship between the wavefunction and the probability density, as well as the correct approach to integrating in spherical coordinates.
Some participants have provided guidance on the normalization process and the use of spherical coordinates. There is acknowledgment of the challenges faced with Mathematica and the integration process, with various interpretations and approaches being explored without a clear consensus on the next steps.
Participants note the complexity of the problem, particularly regarding the integration of functions in spherical coordinates and the use of computational tools. There is also mention of potential typos and misunderstandings about the nature of the functions involved.
zhillyz
The probability density function of the [itex]n-state[/itex] of an electron is proportional to
[itex]f[/itex][itex]n[/itex][itex]=[/itex][itex](\frac{rz}{a_{0}})^{2n}[/itex][itex]e^ \frac{-2Zr}{\large na_{0}}[/itex]
show that the expectation value of the potential energy of the electron in
the [itex]n-th[/itex] quantum state of the hydrogen atoms is;
[itex]\frac{{-Z^2}{e^2}}{\large a_{0} n^2}[/itex]
For that do
(a) derive normalisation factor of the function. (5 marks)
(b) calculate the expectation value for [itex]<1/r>[/itex]. (5 marks).
(c) calculate the expectation value for [itex]< V >[/itex]. (5 marks).
You may use Mathematica or Mathcad for this exercise
Normalization procedure
Take a function [itex]f(x)[/itex] and the Normalizing Constant as [itex]N[/itex] then
[itex]N^2∫f(x)*f(x) dx = 1[/itex]
and
[itex]N = \frac{1}{\sqrt{\large\int_o^\infty f(x)*f(x)}}[/itex]
Put equation into mathematica then square it, then integrate it, then square root it and then divide function by answer?
If integrated from negative to positive infinity it should equal zero?
Wondering if my logic is okay before I move onto expectation values?
and
Yeah, your logic for normalization seems fine. The only thing that I don't understand is the bit in red, which doesn't make sense to me. fn is a function of r, the radial coordinate of the electron right? Well, r can't be less than 0 anyway, since it is a distance. So I don't think you can integrate the function over negative r, but even if you could, I don't understand why you claim that the result would be 0.
Keep in mind that this isn't a purely one-dimensional problem:
[tex]1=N^2\int_{ \text{all space} }|f^2(\mathbf{r})|d^3 \mathbf{r}[/tex]
What is the volume differential in spherical coordinates?
The zero was a typo I meant 1. I have only briefly been exposed to spherical coordinates about a year ago so not sure how I shall use them.
From researching online though I can see that;
[itex]dV = r^2sin\theta \,dr\, d\theta \,d\varphi[/itex].
and
[itex]\int_{\varphi = 0}^{2\pi} \int_{\theta = 0}^\pi \int_{r = 0}^\infty f(r,\theta,\varphi) r^2sin\theta \; dr \; d\theta \; d\varphi[/itex].
I shall see what I can find on using these when I come home.
So I am not entirely sure how I am getting on here, but I think the point in the question stating that MathCad or Mathematica could be used was as the integral is difficult, and as I have never used spherical coordinates or Mathematica I don't know if what I am doing is correct.
Basically I took great effort with the input of my function [itex]'f[/itex][itex]n[/itex][itex]'[/itex] and got the software to square the function which gave me the function below back;
[itex]f[/itex][itex]n[/itex][itex]=\frac{n^2 rZ^4\exp\frac{-4Zr}{an}}{a^4}[/itex]
but then when I integrate it with respect to r from 0 to infinity I get the exact same function back with and infinity symbol on the end.
Also once I have got the correct integral I plan to square root it and divide 1 by the answer to have my Normalization constant which I would then multiply the initial function with to normalize it does this seem correct?
Thank you in advance for any help.
First off, I think I erred in my previous post (and failed to catch your error). You need to distinguish between wavefunction and probability density.
For an un-normalized wavefunction [itex]\Psi(\mathbf{r})[/itex], the normalization constant is given by
[tex]N^2\int_{ \text{all space} } | \Psi(\mathbf{r}) |^2 d^3 \mathbf{r} = 1[/tex]
How is the probability density [itex]f_n(r)[/itex] related to to the wavefunction?
Ahh, the probability density function is the wave function multiplied by its complex conjugate and integrated from one point to another?
probability density function = [itex]f[/itex][itex]n[/itex][itex]= \int \varphi * \varphi \, dr[/itex]
So normalization factor is merely;
[itex]\frac{1}{\large\sqrt{f_n}}[/itex]
Does this seem correct?
No, the probability density is just the wavefunction multiplied by its complex conjugate (not integrated - it's a density after all) [itex]f_n(r)=| \Psi(\mathbf{r}) |^2[/itex] so,
[tex]N^2\int_{ \text{all space} } | \Psi(\mathbf{r}) |^2 d^3 \mathbf{r} = N^2\int_{ \text{all space} } f_n(r) d^3 \mathbf{r} =1[/tex]
You will still need to integrate (do the angles first, and don't forget the factor of r^2 from d^3r when doing the radial integration). If you have trouble getting Mathematica to spit out a useable answer, post your Mathematica input in code tags so we can see what you are doing wrong.
Damn, thought I had got it easy there for a second :) okay 2minutes I will see what I can do.
Right, so I have ignored the Mathematica part of this question so far till I get my head round spherical coordinate integration. The way I see it just now what I need to do is this;
[itex]\int_0^{\pi}\int_0^{2\pi}\int_0^{\infty} f_n\; {d^3}r[/itex]
[itex]{d^3}r = dV = {r^2}sin\varphi dr d\theta d\varphi[/itex]
So in [itex]f_n[/itex] there is no term dependent on[itex]\phi[/itex]or[itex]\theta[/itex] so we can evaluate as follows;
[itex]\int_0^{\pi} sin\varphi \,d\varphi *\int_0^{2\pi} 1 \,d\theta * \int_0^\infty f_n dr[/itex]
which equates to
[itex](-cos \pi + cos 0)*(2\pi)*\int_0^{\infty} f_n(r)*r^2 dr[/itex]
and then I need to get into Mathematica yes?
Integrate[(((rZ)/(a))^(2 n))*(Exp[(-2 rZ)/an])*(r^2), {r, 0, Infinity}]
Integrate::idiv: Integral of r^2 does not converge on {0,\[Infinity]}. >>
Mathematica isn't human, it will interpret "rZ" as a single variable and "r Z" as the product of two variables
Ah okay thank you, and the post before that seem okay to you?
In[8]:= Integrate[(((r Z)/(a))^(2 n))*(Exp[(-2 r Z)/a n])*(r^2), {r,
0, Infinity}]
Out[8]= ConditionalExpression[(
2^(-3 - 2 n) a^3 (Z/a)^(2 n) ((n Z)/a)^(-2 n) Gamma[3 + 2 n])/(
n^3 Z^3), Re[(n Z)/a] > 0 && Re[n] > -(3/2)]
Seems fine to me (although I would rewrite -cos∏+cos0 as 2 :wink:).
Whenever you are computing a multidimensional integral (surface, volume, etc.) as long as the integrand is not a function of more than one variable, and the variables of integration are independent over whatever region you are integrating over, you can rearrange the integrals in that manner/
One thing you should take note of is that the [itex]N[/itex] you will find like this is the normalization constant for the wavefunction. What is the normalization constant for the probability density?
0, Infinity}]
n Z and a are real and positive, and moreover n is and integer. You can tell mathematica this explicitly by adding assumptions to your integrate statement, and thus avoid the conditional statement (and the gamma function) in the answer
I thought I would leave it as -cos pi + cos 0 just to show I had understood the process of integration haha.
Is the the normalization constant of a pdf just integrating the pdf from 0 to infinity?
Sort of. Assume that your pdf is normalized by multiplying by a constant [itex]\alpha[/itex] so that [itex]f_n(r)_{ \text{normalized} } = \alpha f_n(r)[/itex]. Integrating a normalized pdf over all space should give 1 (the probability of finding the electron somewhere in the universe), so you have
[tex]\int_{ \text{all space} } f_n(r)_{ \text{normalized} } d^3 \mathbf{r} = \int_{ \text{all space} } \alpha f_n(r) d^3 \mathbf{r} = 1[/tex]
How does [itex]\alpha[/itex] relate to [itex]N[/itex]?
Integrate[(((r Z)/(a))^(2 n))*(Exp[(-2 r Z)/a n])*(r^2), {r, 0, Infinity}, Assumptions -> {a \[Element] Reals, Z \[Element] Reals,
r \[Element] Reals, a > 0, Z > 0, r > 0, n > 0,
n \[Element] Integers}]
Out[25]= (2^(-3 - 2 n) a^3 n^(-3 - 2 n) Gamma[3 + 2 n])/Z^3
[itex]N^2 = \int_0^{\infty} f_n d^3r = \int_0^{\infty} \alpha f_n d^3r[/itex]
So
[itex]α=\frac{d^3N^2}{d^3r f_n}[/itex]
Is that right?
Careful, Mathematica interprets "Exp[(-2 r Z)/a n" as [itex]e^{ \frac{-2rZ}{a} n}[/itex]. In addition, [itex]\Gamma[z]=(z-1)![/itex] when z is a positive integer.
So
Is that right?
No.
You have [itex]|N|^2 \int_{ \text{all space} } f_n(r) d^3 \mathbf{r} = 1[/itex] and [itex]\int_{ \text{all space} } \alpha f_n(r) d^3 \mathbf{r} = 1[/itex]... [itex]\alpha[/itex] is a constant and can be pulled out of the second integral...
I see [itex]\alpha = N^2[/itex]. Thank you for your patience and help, it is very much appreciated.
