Ductile material engineering stress-strain curve
The discussion centers on the engineering stress-strain curve of ductile materials, particularly focusing on the definitions and distinctions between various points on the curve, such as the proportional limit, elastic limit, yield point, ultimate strength point, and fracture. Participants seek clarification on these concepts and their implications in material behavior under tension tests.
  • Some participants propose that the proportional limit and the limit of linearity are the same.
  • Others argue that the elastic limit is the maximum stress a material can withstand without permanent deformation, while the yield point marks the onset of plastic deformation.
  • There is a question about whether plastic deformation is synonymous with permanent deformation and if there are other forms of permanent deformation prior to the yield point.
  • Some participants inquire about the starting point of nonlinearity in the stress-strain curve, debating whether it begins at the proportional limit or the yield point.
  • Clarifications are sought regarding the concepts of permanent set and strain hardening, particularly in relation to plastic deformation.
  • A participant notes that beyond the proportional limit, some deformation remains upon unloading, which is referred to as permanent set.
  • Strain hardening is discussed as a phenomenon where additional stress is required to further deform a material after the yield point has been reached.
Participants express varying interpretations of the definitions and relationships between the points on the stress-strain curve. There is no consensus on whether the proportional limit or the yield point marks the beginning of nonlinearity, and the discussion remains unresolved regarding the nature of permanent deformation prior to the yield point.
Participants acknowledge a lack of background knowledge on certain topics, such as permanent set and strain hardening, which may limit their understanding of the discussion. There are references to external threads for further insights, indicating that some concepts may not be fully explored within the current thread.
scoutfai
I understand that the engineering stress-strain curve of different material under tension test is different, but for the sake of simplicity the scope of this discussion will be for a general ductile material. If you have to pick a specify example, I think perhaps you can use steel or iron.
There are various reference book out there that explains the stress-strain curve, but all of them vary from each other slightly. So I am a bit confuse and I would like to get some insight from here.
There are many different points in a stress-strain curve, so I will list down in order base on my understanding:
1) Proportional Limit
2) Elastic Limit
3) Yield Point
4) Ultimate strength point
5) Fracture
Questions:
(i) Is the point of proportional limit same as the point of linearity limit?
(ii) If my understanding is correct, elastic limit is the greatest stress the material can take without permanent deformation. Yield point is the point where the material starts to experience plastic deformation. So, is plastic deformation not exactly the same as permanent deformation? Is that means there are many kinds of permanent deformation and plastic deformation just one kind of permanent deformation?
(iii) Does the nonlinearity starts at the elastic limit, yield point or the proportional limit?
I have more questions actually, but it is more suitable to be asked after the above three have been answered. So I looking forward to your opinion. Any help is greatly appreciated.
(1) Yes
(2) Yes, review the definition of permanent set and strain hardening.
(3) The limit of proportionality
You got 3 out of 3, well done and keep asking questions
:biggrin:
Studiot said:
(1) Yes
:biggrin:
Thanks for the encouragement :blushing:
Some follow up questions:
(2.1) If plastic deformation is only a kind of permanent deformation, then prior to the yield point, what kind of permanent deformation is taking place?
(2.2) I do not have the background on these topics (permanent set and strain hardening). Can you give me some insights?
(2.3) Since plastic deformation is happens at the end of the stress-strain curve, can we say that the plastic deformation is the ultimate, "last thing to happen", in the world of permanent deformation? Mean there is no other kind of permanent deformation occurs after plastic deformation happens in a material.
(3.1) If the proportional limit is the end of linearity and beginning of nonlinearity, why there are resources which take yield point as the beginning of nonlinearity? Which one is actually correct?
Did you look them up?
First a note on the word 'elastic'.
In principle, Elastic Behaviour means that if you load a specimen it will deform at least some of this deformation will be restored if you then remove the load.
It does not mean that deformation is linearly proportional to load. This is linear elastic or hookean behaviour which behaviour also means that the whole of the deformation is recovered.
So beyond the limit of proportionality unloading still causes recovery of the deformation.
However beyond the proportionality limit it is found that on unloading some deformation remains.
This deformation is known as permanent set have a look at this thread.
https://www.physicsforums.com/showthread.php?t=479133&highlight=permanent+set
As regards plasticity look here
https://www.physicsforums.com/showthread.php?t=395692
Strain hardening is an acknowledgment that once the yield point has been passed it requires an increase in stress to further deform the specimen. This increase is known as strain hardening or work hardening. The material does indeed become harder and stronger under plastic flow as the crystal structure is rearranged. The work is the extra work under the curved section of the stress strain curve.
17K
