Word Equation: Copper (II) Sulfate + Zinc -> Zinc Sulfate + Copper (II)
  • Thread starter Thread starter UrbanXrisis
The chemical reaction between Copper (II) sulfate and Zinc results in the formation of Zinc Sulfate and Copper. The correct representation of this reaction is Zn + CuSO4 → Cu + ZnSO4. The discussion clarifies that the product Copper is elemental copper, not copper(II) ions, and emphasizes that the reaction conditions, such as pressure and temperature, influence the outcome. It is established that the first equation balances correctly, while the second does not maintain charge balance.
  • Understanding of chemical reactions and stoichiometry
  • Familiarity with ionic compounds and their representations
  • Knowledge of reaction conditions affecting chemical processes
  • Basic principles of charge balance in chemical equations
  • Research the effects of temperature and pressure on chemical reactions
  • Study the principles of ionic and molecular compounds
  • Learn about balancing chemical equations and charge conservation
  • Explore the properties and reactions of Copper (II) sulfate in aqueous solutions
Chemistry students, educators, and professionals interested in reaction mechanisms and chemical equation balancing.
UrbanXrisis
When Copper (II) sulfate is added to Zinc, it becomes Zinc Sulfate and Copper, but is the copper an ion [copper(II)]? or is it just copper?
Zinc+Copper (II) sulfate -> Zinc Sulfate + Copper
or
Zinc+Copper (II) sulfate -> Zinc Sulfate + Copper (II)
Chemistry news on Phys.org
Depends on the medium of reaction... :wink: For example if Cu(II)SO_{4} is solid (anhidrous) crystal and u add a piece of solid zinc,there would be no chemical reaction... :-p
Basically the reaction,under certain conditions (pressure,temperature,aqueous solution) should go
[tex]Zn+CuSO_{4}\rightarrow Cu\downarrow +ZnSO_{4}[/tex]
If you want to write the ionic reaction,be my guest.
Daniel.
or
The first is correct.
The second does not balance charge.
  • · Replies 26 ·
