Finding x in an inverse trigonometric equation
The discussion revolves around finding the variable x in the context of an inverse trigonometric equation involving arctan. The original poster expresses difficulty in approaching the problem, questioning whether it is solvable.
  • Participants explore the relationship between y and x in the context of the arctan function, discussing how to isolate x. There are questions about the nature of the problem and whether setting y to specific values could aid in finding x. Some participants suggest taking the tangent of both sides as a potential approach.
There is an ongoing exploration of the problem with various interpretations being discussed. Some participants have provided guidance on manipulating the equation, while others are still grappling with the concepts involved. Progress has been noted, but no consensus has been reached on the final approach.
Participants are navigating the complexities of inverse trigonometric functions and their properties. There is a recognition of the need to carefully handle constants in the equations, and some participants express uncertainty about their understanding of the material.
acen_gr
Given y = 2/3(arctan [itex]\frac{x}{4}[/itex]), find x.
Inverse trigonometric identities for tan. (I guess)
I never attempted because it seems impossible for me. You think this is possible? Thank you!
If y = arctan(x), what is x?
And by "what is x" or "find x" we mean to make x the subject, so we'll have something like x = ... (or if you understand how functions work, x will be a function of y which can also be written as x=f(y) ).
Yes. That's why I'm so confused with this. Is it just like "what must be the value of x to be y"?. At first, I really don't get this. But I think we should set y = 0 (like the way of how x-intercepts are found). Is it possible to find x that way? Or is this problem again makes no sense?
EDIT: Or do I make no sense with this reply?
If y=3x, then x=y/3
If [itex]y=x^2[/itex], then [itex]x=\pm\sqrt{y}[/itex]
If [itex]y=arctan(x)[/itex] then [itex]x=...[/itex]?
In other words, what do you do to arctan(x) to make it go back to x again? What we did to x2 is we took the square root (and we have to take the square root of both sides). What we did to 3x is we divided it by 3 (and we divided both sides). This operation is called taking the inverse.
The inverse of squaring, is square-rooting. The inverse of multiplying is dividing. The inverse of sin is arcsin (or sin-1) and the inverse of arcsin is sin. So what is the inverse of arctan?
Mentallic said:
If y=3x, then x=y/3
I know! I know! Should we take the tangent? of both sides?
[tex]y = \frac{2}{3}(arctan\frac{x}{4})[/tex]
leave arctan alone:
[tex]\frac{3}{2}y = arctan\frac{x}{4}[/tex]
take tangent of both sides:
[tex]tan\frac{3}{2}y = \frac{x}{4}[/tex]
I should stop right here. Am I doing it right?
EDIT: To continue,
[tex]x = 4tan\frac{3}{2}y[/tex]
Yes! If [tex]y=\arctan(x)[/tex] then to simplify it we take the tangent of both sides: [tex]\tan(y)=\tan(\arctan(x))[/tex]
And the tan and arctan cancel each other, so we end up with [tex]x=\tan(y)[/tex]
Now, for your problem, you don't want to take the tangent straight away, because your question isn't in the form [tex]y=\arctan(x)[/tex] you instead have a constant multiplied in front of the arctan, so you should get that to the other end first before taking the tangent.
leave arctan alone:
EDIT: To continue,
Yep! :smile:
Now just be sure to put brackets around 3y/2 because you can easily mistake it for something else like tan(3/2)*y which would be wrong.
Then the answer should be
[tex]x = 4tan(\frac{3y}{2})[/tex]
YES! Finally I made something right in my life again! Especially in math. Thank you! :)
@Offtopic, you really are a great teacher in math. Do you teach? Are you a professor or the like?
No problem dude! And I'm glad to see that you're making progress.
Cheers :smile: Nah I'm just a math student myself. But I've been on this forum for like 3 or 4 years now, so I've learned a thing or two about how to teach others while not breaking the forum rules by giving out full solutions and the like.
Really? How come you seem to know a lot in math? Have you just memorized everything about math?
EDIT: Wee I'm so encouraged to work hard in math...knowing that even a math student can also be as good as teachers, and sometimes BETTER. I wish I could be like you too. You're a student like me yet you are like a math teacher! How did you become a homework helper?
Far from it. I haven't forgotten the important formulae that get me through the day, but to solve equations, puzzles, and basically just applying your knowledge of maths becomes a lot easier when you have a firm grasp of your algebra, trig and calculus.
I mean, if you looked at some early high school problems, even though you might have never answered that particular problem before, you would probably have an easy time answering it, right? Well, it's the same situation here.
You mean, you learned to solve anything because you have already encountered them? Or the opposite?
So, I should have studied a lot in algebra, trigo and calculus?
