Drag Deceleration: Bullet Drag Basics
  • Thread starter Thread starter sirasher
    Deceleration Drag
The drag of a standard bullet typically ranges from a drag coefficient (Cd) of 0.2 to 0.4, with 0.3 being common under standard trajectory conditions. At supersonic speeds, a bullet can experience a drag force of approximately 0.2 to 0.3 lbs, which increases as the bullet decelerates. Factors such as bullet shape, weight, muzzle velocity, and atmospheric conditions significantly influence drag. Optimal performance requires careful consideration of these variables, particularly air density, temperature, and humidity.
  • Understanding of drag coefficients in aerodynamics
  • Knowledge of bullet physics and ballistics
  • Familiarity with atmospheric conditions affecting projectile motion
  • Basic principles of supersonic flight dynamics
  • Research the impact of air density on bullet trajectory
  • Study the relationship between bullet shape and drag coefficient
  • Explore the effects of temperature and humidity on projectile performance
  • Learn about advanced ballistics software for trajectory analysis
Ballistic engineers, firearms enthusiasts, and anyone involved in precision shooting or projectile design will benefit from this discussion.
sirasher
Can anyone tell me the drag of a standard bullet? I realize there are lots of variables affecting this, but what is the ideal amount of drag without considering particulr weather conditions.
Of course, you correctly mentioned that numerous factors affect the Drag Coefficient. Keeping that in mind, the following NASA site provides some "typical" values you might find useful. Values in the literature generally range from Cd=(0.2) to Cd=(0.4), with Cd=(0.3) somewhat typical for usual trajectory and environmental parameters.
http://www.grc.nasa.gov/WWW/K-12/airplane/shaped.html
The drag of a standard bullet can vary greatly depending on several factors such as the shape and weight of the bullet, the muzzle velocity, and the atmospheric conditions. However, on average, a standard bullet can experience a drag force of around 0.2 to 0.3 lbs at supersonic speeds. This drag force increases as the bullet slows down and approaches the speed of sound.
It is difficult to determine an ideal amount of drag without considering specific weather conditions as they play a significant role in the bullet's trajectory and deceleration. Factors such as air density, temperature, and humidity can affect the bullet's drag and ultimately its flight path.
In general, a higher drag force can help stabilize the bullet and improve accuracy, especially at longer distances. However, too much drag can also slow down the bullet and reduce its range. Therefore, it is important to consider the specific weather conditions and adjust the bullet's drag accordingly for optimal performance.
  • · Replies 24 ·
  • · Replies 88 ·
10K
9K
13K
