New Reply
If you had $1000 to build a generator...
Share Thread Thread Tools
Sep21-12, 01:47 AM   #1
...build a generator that uses renewable energy, what type of energy would you invest in?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Sep21-12, 02:28 AM   #2
What do you have the most of where you live, sun, wind, or spare vegetation?
Sep21-12, 03:16 AM   #3
Equal amounts of all of them, relatively speaking.
There is not one that is more apparent than the other.
Or put in a better way - you could take the generator anywhere you want that inhabits people, except for "extreme" locations.
Sep21-12, 03:51 AM   #4
In that case, I suppose the best bet is a methane digester because it would be the least intermittent.
Sep21-12, 04:36 AM   #5
Admin
Biogas? Walking with that tube must be quite uncomfortable.
Sep21-12, 04:54 AM   #6
Mentor
$1000 isn't that much. A quick google tells me I'd be lucky to get a 1kw solar panel in the UK with that.
Sep21-12, 01:08 PM   #7
Quote by Ryan_m_b View Post
Yes it's not a lot, but solar panels are very expensive.
Quote by zoobyshoe View Post
Wouldn't hydroelectric energy also be much easier to develop and not intermittent if near a body of water.
Sep28-12, 10:36 AM   #8
Pretty open ended question a REAL answer would be influenced by many factors, As stated - I would go solar with battery storage, low maintenance simple device - etc. Then just use the DC and/or small inverter to power AC items directly.
Developing a complete digester system or hydro for $1000 - would be a challenge.
Sep28-12, 01:23 PM   #9
I could do it for that cost. I'd wait until hurricane season is over, and buy a generator cheap on eBay. New never used, unless we actually get hit by a hurricane. Look for a dual fuel model, using gasoline or propane. Then change out the propane orifice out to burn methane. Put an alcohol kit into it. Now you can run on either alcohol or methane. But be careful of the swamp gas. It has lots of stuff in it that are not good for the engine.
New Reply
Tags
build, energy, generator, renewable
Thread Tools
Similar Threads for: If you had $1000 to build a generator...
Thread Forum Replies
How to build a human powered generator Electrical Engineering 16
Van de Graff Generator: Electrostatics, why do objects repel the generator Advanced Physics Homework 0
Want to build a home-made generator.. Electrical Engineering 4
Flywheel Generator - Split from Propane Solar Collector/Generator Thread Mechanical Engineering 52
