Free Fall Object: Time and Height Calculations from Rest | Homework Equations
  • Thread starter Thread starter steven1495
    Fall Free fall
The problem involves calculating the time and height of an object in free fall, given that it travels half its total distance in the last second of its fall. The subject area is kinematics, specifically focusing on constant acceleration due to gravity.
  • Participants discuss the use of equations for constant acceleration and question the role of mass in the problem. Some suggest using specific kinematic equations, while others explore the implications of the distance traveled in the last second. There are attempts to clarify the relationship between total distance and time.
The discussion is active, with participants offering various equations and approaches. Some guidance has been provided regarding the nature of the problem and the importance of correctly interpreting the distance traveled in the last second. Multiple interpretations of the problem are being explored.
Participants note the known values of acceleration and initial velocity, while expressing uncertainty about the correct application of equations and the resulting distances calculated. There is mention of a potential discrepancy in the distances calculated for various time intervals.
steven1495
If an object travels half its total path in the last second of its free fall, from rest, find:
(a) the time, and
(b) the height of the fall
I'm not sure at all what equations to use
The only thing I can think of is just assuming a mass of an object, and guessing the time, but I didn't have any luck with this
an object in free fall is just a one-dimensional constant acceleration problem with an acceleration of -9.8 m/s2
If you recall your equations of one-dimensional constant acceleration, you should remember that mass does not play a role. At least in a simplified problem like this one.
If the object falls half its total distance traveled in the last second, that means that it also fell the first half of its distance in a time equal to the total time minus one second
Would a good equation for this be:
d=V1Δt+ 1/2 at2
d=V1Δt+ 1/2 at2
Yes, that's equation for constant acceleration.
For easier calculation, assign acceleration as positive.
Write down all the known data and the unknown data.
If there are 3 unknown data, then you have to find 3 independent equations.
the known data is
a= -9.800 m/s^2
Vi= 0 m/s
I used the above equation to find the distances with the times, but all the times I did (up to 6 seconds) didn't work, because after 6 seconds, the distance for the last second was less than the sum of all the other distances
Maybe you sketch a velocity vs. time graph.
The area under the graph is the displacement.
  • · Replies 38 ·
