Diameter of copper wire to have same resistance as equal length aluminum wire
The diameter of a copper wire required to match the resistance of an equal length aluminum wire with a diameter of 3.94 mm is calculated using the formula R = ρL/A. Given the resistivity values of copper (1.72x10-8 Ωm) and aluminum (2.82x10-8 Ωm), the correct diameter for the copper wire is approximately 3.08 mm. The initial calculation of 55.31 mm was incorrect due to an error in determining the cross-sectional area of the aluminum wire. The correct area for the aluminum wire is 3.88x10-6 m2, leading to the accurate copper wire diameter.
  • Understanding of electrical resistance and resistivity
  • Familiarity with the formula R = ρL/A
  • Knowledge of cross-sectional area calculations for circular wires
  • Basic concepts of material properties, specifically resistivity of copper and aluminum
  • Learn about the resistivity of different materials and how it affects electrical resistance
  • Explore the impact of wire diameter on resistance in electrical circuits
  • Study the differences between annealed and plain copper in terms of resistivity
  • Investigate practical applications of resistance calculations in electrical engineering
Electrical engineers, physics students, and anyone involved in designing or analyzing electrical circuits that require precise resistance calculations.
Northbysouth
What diameter must a copper wire have if its resistance is to be the same as that of an equal length of aluminum wire with diameter 3.94mm?
Give your answer in mm
R = ρL/A
where A is the cross sectional area, L is the length and ρ resistance of the material
ρCopper = 1.72x10-8 Ωm
ρAluminum = 2.82x10-8 Ωm
So I knew that Rcopper = RAluminum
(1.72x10-8Ωm)(L)/Acopper = (2.82x10-8Ωm)(L)/(0.00394m)
A = 0.00240 m
A = πr2
r = 0.027657 m
diameter = 55.31499 mm
But the system says its wrong and I don't see where I've gone wrong.
R = ρL/A
Start with what I've highlighted above in red.
  • What are units for area: meters or square meters?
  • Before calculating the cross section area of the copper wire, first ask, what is the cross sectional area of the aluminum wire? :wink:
[Edit: On a much lesser note, and I'm not sure if this matters, according to some sources I've looked at on the Internet, 1.72x10-8 Ωm is the resistivity of annealed copper. Plain old copper has a very similar resistivity, but slightly different. Use whatever your course material advises. And again, the difference is small and I'm not sure if copper vs. annealed copper matters.]
I see what you're saying.
The cross section area od aluminum is π(0.00197m)2
3.8809x10-6 m2
Then solving for the cross sectional area of copper I get
Acopper = 7.4364x10-6 m2
rcopper wire = sqrt(7.4363x102/π)
Diameter of copper wire = 2r = 3.077059 mm
Thanks for your help
24K
