What is the pH of a solution containing 50 grams of Na3PO4?
  • Thread starter Thread starter relativitydude
    Dissociation Type
The discussion revolves around calculating the pH of a solution containing 50 grams of sodium phosphate (Na3PO4). Participants explore the chemical dissociation of Na3PO4 in water, the relevant equilibrium constants, and the implications for pH, with a focus on theoretical and conceptual aspects of acid-base chemistry.
  • One participant calculates the molarity of Na3PO4 as 0.305 M and attempts to relate it to the dissociation in water, expressing uncertainty about the value of Kb.
  • Another participant requests clarification on the dissociation reaction, suggesting that the initial formulation may be incorrect.
  • Some participants discuss the role of water as an acid in the reaction, with one suggesting that water can lose an H+ to form hydroxide ions.
  • A participant mentions that the hydrolysis of Na3PO4 may not be complete, indicating the presence of other species like Na2HPO4 and NaH2PO4.
  • There is a suggestion that the pH will depend on the strength of the conjugate acids and bases involved, with some arguing that the base contributes significantly to the pH.
  • One participant emphasizes the importance of specifying the concentration "per liter" in the problem statement.
  • Another proposes a stoichiometric approach to find the concentration of hydroxide ions based on the dissociation of PO4^3-.
  • There are discussions about the equilibrium constants and the assumption that the equilibrium shifts completely to the right due to a small third dissociation constant.
Participants express differing views on the correct formulation of the dissociation reaction and the role of water. There is no consensus on the value of Kb or the complete nature of the hydrolysis, indicating multiple competing perspectives remain.
Some participants note missing assumptions regarding the specific acid involved and the implications of the concentration of Na3PO4. The discussion also highlights the complexity of determining pH in solutions with multiple equilibria.
This discussion may be of interest to students and educators in chemistry, particularly those focused on acid-base equilibria and pH calculations in solutions.
relativitydude
I think that is what you call it. I need to find the pH of a solution containing 50 grams of Na3PO4.
50 g ---- > 0.305 M
We know that Kw=Ka*Kb
So,
Na3PO4 + H20 --> HNa3PO4 + OH (I think)
Kb = x^2/(.305-x)
I can't find the value of Kb anywhere in my book, internet. If I had it I could calculate Ka and get my pH. Otherwise I am stumped.
Chemistry news on Phys.org
Do you mind if I'm asking you to write the dissociation relation correctly...?
Daniel.
MMM? Doent 10^-14 = Kw = Ka*Kb
and Na3PO4 + H20 --> HNa3PO4 + OH
(Base) (Acid) (Con A) (Con B)
Initial: .305M -- 0 0
Change -x -- +x +x
Final: .305 -x -- x x
Kb = products/reactants = [x][x] / [.305 - x]
If I knew what the value of Kb was for Na3PO4, I could get x and calculate the pOH and ofcourse get the pH.
The chemical (well,ionic) reaction is incorrectly written...Think it viceversa:the base +acid--->Na phosphate+water.
Daniel.
The problem doesn't mention any specific acid and all the preceeding problems use water in the reactants. Anyhow, can't water be considered an acid (thats browsy rule or something)?
I thought the Base would pick up an H+ and since the H20 lost an H, it would simply become hydroxide
I saw it like
[tex]Na_{3}PO_{4}+3H_{2}O\rightleftharpoons H_{3}PO_{4}+3NaOH[/tex]
Anyway,pay attention with the solving and about the data that u're missing,i don't know,maybe someone else would guide u better...
Daniel.
The hydrolysis may not be complete, and so you might also have Na2HPO4 and NaH2PO4. From thie equilibrium constants you can tell which one (if any) is dominant.
In cases such as these you observe the corresponding cationic and anionic components of the salt, the pH will differ according to whether the conjugates of such are strong acid/bases. In this case the base will contribute to the pH. Usually for these types of problems, we can neglect matters regarding the formation H2PO4 since the conjugate base of it is a fairly weak base.
what's this?
50 g ---- > 0.305 M
Why don't you try stating the problem word by word.
#80.
Trisodium phosphate (Na3PO4) is available in hardware stores as TSP and used as a cleaning agent. The label on a box of TSP warms that the substance is very basic. What is the pH of a solution containing 50.0 g of TSP per liter?
Do you see why it's important to not leave out the "per liter" ?
I suppose that they want us to assume that it is a strong base
-The net equation will consist of aqueous [tex]PO_4^-3[/tex] reacting with a hydronium cation [tex]H_3O^+[/tex] to produce [tex]HPO_4^-2[/tex] and [tex]H_2O[/tex] Write and balance out this equation.
-You can than deduce the final concentration of [tex]OH^-[/tex] from finding the initial molarity of the [tex]PO_4^-3[/tex], there is a stochiometric one to one equivalence of the compound to this anion, so find the initial molarity of the compound and this will be the concentration of the anion.
-Use the balanced equation to find the stoichiometric ratio of the anion to the hydroxide.
-Use this to find the [tex]p_{OH}[/tex] then deduce [tex]p_H[/tex]
GeneralChemTutor said:
The net equation will consist of aqueous [tex]PO_4^-3[/tex] reacting with a hydronium cation [tex]H_3O^+[/tex] to produce [tex]HPO_4^-2[/tex] and [tex]H_2O[/tex].
And why not [tex]PO_4^3^- + H_2O \rightarrow HPO_4^2^- + OH^-[/tex]?
Due to a very small third dissociation constant you may assume that the equilibrium is shifted 100% to the right - the you may proceed as you have proposed, but this way you don't have to introduce [tex]H_3O^+[/tex] ions.
Chemical calculators for labs and education
BATE - pH calculations, titration curves, hydrolisis
The base will react with the strongest acid.
That is the base increases the pH level by first reacting with the strongest acid , the [itex][H^+][/itex] level decreases as a result. You can guess what happens next.
16K
14K
