Calculate the flux that passes through the floor
  • Thread starter Thread starter figs
    Flux
The discussion revolves around calculating magnetic flux through a wall and a floor in a house, given the Earth's magnetic field components. The problem involves understanding the orientation of magnetic fields and surfaces in relation to flux calculations.
  • Participants discuss the application of the magnetic flux formula, questioning the orientation of the magnetic field components relative to the surfaces. There is uncertainty about which components contribute to the flux through the wall and the floor.
Some participants have provided insights into the contributions of horizontal and vertical magnetic field components to the flux calculations. There is ongoing exploration of the correct approach to determine the flux, with no explicit consensus reached yet.
Participants express confusion regarding the relationship between the magnetic field components and the orientation of the surfaces, indicating a need for clarification on these concepts.
figs
A house has a floor area of 200 m^2 and an outside wall that has an area of 50.0 m^2. The Earth's magnetic field here has a horizontal component of 2.58×10^-5 T that points due north and a vertical component of
4.14×10^-5 T that points straight down, toward the earth. a)Determine the magnetic flux through the wall if the wall faces north. b)calculate the flux that passes through the floor.
a)
flux=BAcos(theta)
=(4.14*10^-5)(50 m^2)(cos 90 deg)
=0 Wb
b)
flux=BAcos(theta)
=(2.58*10^-5)(200 m^2)(cos 0 deg)
=5.16*10^-3 Wb
I'm not sure what I did wrong.
At point a) it's the horizontal component which gives the nonzero flux...
As for point b),it's viceversa,only the vertical one does.
Daniel.
A house has a floor area of 200 m^2 - normal points vertical - a vertical component of 4.14×10^-5 T that points straight down,
An outside wall has an area of 50.0 m^2. The wall's normal is horizontal, The Earth's magnetic field here has a horizontal component of 2.58×10^-5 T that points due north.
im still in the dark about this vertical horizontal component
do i need to find some magnitude before i find the flux?
19K
