Find total ionic (balanced equation) for this particular reaction.
  • Thread starter Thread starter name_ask17
    Ionic Reaction
The total ionic equation for the reaction between calcium hydroxide and phosphoric acid in aqueous solution is derived from the balanced equation 3Ca(OH)2 + 2H3PO4 --> Ca3(PO4)2 + 6H2O. Calcium hydroxide (Ca(OH)2) dissociates completely into 3Ca2+ + 6OH-, while phosphoric acid (H3PO4) is a weak acid that partially dissociates, primarily releasing the first proton. The final total ionic equation considers calcium phosphate (Ca3(PO4)2) as insoluble, leading to the conclusion that both Ca(OH)2 and H3PO4 should be treated as solids in the total ionic equation.
  • Understanding of solubility rules in aqueous solutions
  • Knowledge of weak and strong acids and bases
  • Ability to balance chemical equations
  • Familiarity with ionic dissociation in solutions
  • Study the solubility rules for common ionic compounds
  • Learn about the dissociation of weak acids and bases in solution
  • Explore the concept of total ionic equations in chemical reactions
  • Review examples of balancing complex chemical reactions
Chemistry students, educators, and anyone studying chemical reactions in aqueous solutions, particularly those focusing on acid-base reactions and solubility principles.
name_ask17
Find the total ionic (balanced) equation of the reaction of calcium hydroxide and phosphoric acid in aqueous solution.
Solubility rules
First, I balanced the reaction.
The part I'm stuck at is I don't know what to break up and what to leave. I know the solubility rules, but for some reason I keep getting this question wrong.
I know that Ca(OH)2 can break up into 3Ca2+ + 6OH-
But is that the only one that breaks up?
I looked it up and I'm getting mixed results. Please help me if you can. Thanks in advance.
No idea what the correct answer is, as unfortunately it depends on what the teacher had on mind :frown:
Calcium hydroxide is weakly soluble (so mostly present as a solid), but it is a strong base (so it is 100% dissociated).
Phosphoric acid is a weak acid, so in typical solution it will be dissociated only partially, and only the first proton will be dissociated in substantial amounts (for example in 1M solution about 8%), yet it can react all the way down to PO43-.
Apparently you are expected to ignore some of these information and give answer based on some general (but not always correct) rules.
Thank you so much. I figured it out. They wanted me to look as phosphoric acid and calcium phosphate, both as insoluble. Thanks again!
12K
25K
13K
