Discontinous functions question.
  • Thread starter Thread starter peripatein
    Functions
The discussion revolves around the continuity of the step function f(x) = [x], particularly at integer values. Participants explore the conditions for continuity and the behavior of limits at specific points.
  • Participants examine the three conditions for continuity and question which of these are unmet for the function f(x). There is a focus on the limits from both sides of integer values and whether they exist and are equal.
Some participants are seeking clarification on the limits at specific points and whether the function meets the requirements for continuity. There is a mix of interpretations regarding the instructor's claims and the conditions of the function.
Participants reference the step nature of the function and its behavior around integer values, noting that the limits from above and below may not be equal. The discussion includes questioning the existence of limits at integer points.
peripatein
Hi,
For a function to be continuous, three conditions must be met - the function must be defined at a point x0, its limit must exist at that point, and the limit of the function as x approaches x0 must be equal to the value of the function at x0.
Now, assuming my function is f(x)=[x], which assigns an integer smaller than x to f(x). Thus, if 1≤x<2, f(x)=1.
The instructor claimed that this function is discontinuous for every integer x, which is perfectly clear just from looking at the graph of f(x), which is a step graph. He also mentioned that two of the three requirements for continuity are unmet in this case.
Which two requirements of the three above are unmet in this case?
peripatein said:
Hi,
For the limit to exist, the left- and right-side limits have to exist and be equal. You're dealing with a step function that has jumps at integer values. Take a look at the three conditions at these integer values.
The instructor claimed that for a limit to exist at a point x0, the limit has to be equal both from above and below, unless the limit from one direction does not exist and then the limit at x0 DOES exist. Hence, that requirement is met for the step function as described above, I believe. Is it not?
Another requirement that is met is that the function is defined for any x0. Is it not?
So two requirements are already met and that alone disagrees with the instructor's claim that two conditions are unmet.
Could someone please clarify? What am I missing?
For your function, what are
$$ \lim_{x \to 1^-} f(x)?$$
and
$$ \lim_{x \to 1^+} f(x)?$$
Do both exist? If so, are they equal?
No, the function f(x) = [x] does not have a limit as x → n, for every integer n. The limits exist in BOTH directions, however. (Why do these two statements not contradict each other?)
RGV
Mark, is the limit from below equal to 0, whereas the limit from above is equal to 1?
and
Do both limits indeed exist and whereas the first is equal to 0, the second is equal to 1?
May someone please clarify?
What is f(0.9)? What is f(0.99)? What is f(1.1)? What is f(1.01)? Can you see now what is happening?
RGV
Well, as x approaches 1 from below f(x) is still 0 (or does that limit not exist?). When x approaches 1 from above, f(x) is 1. Is that correct?
Yes. So
$$ \lim_{x \to 1^-} f(x) = 0$$
and
$$ \lim_{x \to 1^+} f(x) = 1$$
So does ##\lim_{x \to 1} f(x) ## exist?
Can you now answer the question about whether f is continuous?
Yes, Mark. Thank you very much! :-)
  • · Replies 23 ·
