Magnetic moment due to applied external magnetic field
The discussion focuses on calculating the externally applied magnetic field (B_{0}) required for 51% of metal ions in CuSO4 to align their magnetic moments with the field at room temperature. The relevant equations include the relationship B = μ0(H + M) and the susceptibility formula χ = (N/V)((pμB)²μ0)/(3kBT). The user concludes that the magnetization M can be expressed as M = μN(p - q), leading to the formula B0 = (KBT/μ)(p - q) for determining the necessary magnetic field.
  • Understanding of magnetic susceptibility and its implications in solid-state physics
  • Familiarity with the concepts of magnetization and magnetic moments
  • Knowledge of statistical mechanics, particularly the Boltzmann distribution
  • Basic proficiency in using equations related to magnetic fields and materials
  • Explore the concept of magnetic susceptibility in detail, particularly in solid-state physics
  • Study the Boltzmann distribution and its application to magnetic systems
  • Learn about the gyromagnetic ratio and its significance in magnetic moment calculations
  • Investigate the relationship between temperature, magnetic field strength, and material properties
Students and professionals in solid-state physics, materials science researchers, and anyone interested in the behavior of magnetic materials under external fields.
Kentaxel
How large externally applied magnetic filed ([itex]B_{0}[/itex]) is necessary in otder for 51% of the metal ions in CuSO([itex]_{4}[/itex]) to have their magnetic moments oriented in the same direction as the applied field when the salt is kep at room temperature?
[itex]B=\mu_{0}(H+M)[/itex]
[itex]\chi=\frac{N}{V}\frac{(p\mu_{B})^{2}\mu_{0}}{3k_{B}T}[/itex]
rearanging the relation
As i understand it i want
[itex]M=0,51H[/itex]
then, using
[itex]\chi B_{0}=\mu_{0}M[/itex]
i find that
[itex]\chi=0,51[/itex]
But [itex]\chi[/itex] is, as i understand it, independent on applied magnetic field [itex]B_{0}[/itex] so this reasoning can't be right. However i fail to see what I'm missing.
Maybe i should say this is Introductory Solid state physics. I'd modify the title but I'm not sure i can?
I think i figured this out, so i'll post the results here in case someone would find it useful.
To calculate the amount of atoms with a spin state corresponding to the applied magnetic field one would calculate the amounting magnetisation due to the number of atoms existing in that desired state.
So that the ratio of atoms per volume existing in spin up [itex]n_{1}[/itex] to the total amount of atoms per volume N becomes:
[itex]p=\frac{n_{1}}{N}[/itex]
Where in the above stated problem one would have p=0.51, and the remaining atoms existing in a spin down state is simply
[itex]q=1-p[/itex]
The the resulting magnetisation would be
[itex]M=μN(p-q)[/itex]
Combining this with the statistical calculation of the number of states one gets
[itex]μN(p-q)=μNtanh(\frac{μB_{0}}{k_{B}T})\approx μN(\frac{μB_{0}}{k_{B}T})[/itex]
[itex]\Rightarrow B_{0}=\frac{K_{B}T}{μ}(p-q)[/itex]
And after determining μ (with the gyromagnetic ratio etc.) one would obtain the desired result
