Battery and potential difference
The discussion revolves around the behavior of a parallel plate air gap capacitor after being charged by a battery and subsequently having its plates separated. Participants explore the implications of this separation on the potential difference between the plates.
  • Participants discuss the relationship between resistance, distance, and potential difference, with some questioning the relevance of resistance in this context. Others consider the role of the electric field and the work done in separating the plates.
The discussion is active, with various interpretations being explored regarding how the potential difference changes as the plates are separated. Some participants suggest that the potential difference increases, while others provide reasoning based on electric field concepts and capacitance relationships.
There is a mention of relevant equations related to charge, distance, and area, indicating that participants are considering the mathematical relationships involved in the problem. The absence of the battery is also a critical factor in the discussion.
thisisfudd
A battery fully charges a parallel plate air gap capacitor. The battery is removed and the plates are pulled apart. What happens to the potential difference between the plates as they are being separated?
So I guess resistance and I operate over a certain length. So the length is increasing, so that means resistance and length increase, so potential difference increases? Is this correct logic?
What resistance? caps should have infinite resistance between the plates. There is an equation relating charge to the distance between the plates isn't there?
Well if the electric field stays the same and distance increases than electric potential would increase. A batterys job is simply to move electrons from one plate to another basically, so with no battery connected no electrons could be moved from each plate to make up for the change in distance and the potential would increase, correct?
The Potential would increase, as work is required to move the plates apart.
Claude.
When you think capacitance you involve capactiance concepts when trhe question asks about the potential difference between the two plates!
i believe you have a formula for the voltage across two plates in a parallel plate capacitor whjich is related to the charge, distance and area of the two plates. Since you only change one thing d (distance between the plates) V will change accordingly
