Field and Displacement Inside Carvities Within A Dielectric
The discussion focuses on calculating the electric field and displacement within cavities in a dielectric material, specifically addressing three scenarios: a spherical cavity, a needle-shaped cavity, and a wafer-shaped cavity. For the spherical cavity, the new electric field is expressed as \(\vec{E}_{new} = \vec{E}_{0} + \frac{1}{3\epsilon_{0}} \vec{P}\) and the displacement as \(\vec{D} = \vec{D}_{0} - \frac{2}{3}\vec{P}\). In the case of the needle-shaped cavity, the field remains approximately equal to \(\vec{E}_{0}\) due to the negligible effect of the dipole field. For the wafer-shaped cavity, the electric field is calculated as \(\vec{E}_{new} = \vec{E} + \frac{1}{\epsilon_{0}}\vec{P}\), confirming the correctness of the approach.
  • Understanding of electric displacement \(\vec{D}\) and polarization \(\vec{P}\)
  • Familiarity with dielectric materials and their properties
  • Knowledge of electrostatics, specifically Gauss's law
  • Ability to perform vector calculus, particularly gradient operations
  • Study the derivation of electric fields in dielectric materials using Gauss's law
  • Learn about the effects of polarization on electric fields in various geometries
  • Explore advanced topics in electrostatics, such as boundary conditions in dielectrics
  • Investigate numerical methods for simulating electric fields in complex dielectric structures
Students and professionals in electrical engineering, physicists, and anyone involved in the study of electrostatics and dielectric materials will benefit from this discussion.
relativespeak
Suppose the field inside a large piece of dielectric is [itex]\vec{E}_{0}[/itex], so that the electric displacement is [itex]\vec{D}_{0}=\epsilon_{0}\vec{E}+\vec{P}[/itex].
a. Now a small spherical cavity is hollowed out of the material. Find the field at the center of the cavity in terms of [itex]\vec{E}_{0}[/itex] and [itex]\vec{P}[/itex]. Also find the displacement at the center of the cavity in terms of [itex]\vec{D}_{0}[/itex] and [itex]\vec{P}[/itex].
b. Do the same for a long needle-shaped cavity running parallel to [itex]\vec{P}[/itex].
c. Do the same for a thin wafer shaped cavity perpendicular to [itex]\vec{P}[/itex]
[itex]\vec{D}_{0}=\epsilon_{0}\vec{E}[/itex] when [itex]\vec{P}=0[/itex] (inside the cavity).
For each part, I found the E of the cavity as if it were a solid piece, and then subtracted that from [itex]\vec{E}_{0}[/itex] to account for the change in [itex]\vec{E}[/itex]. Then, because [itex]\vec{D}_{0}=\epsilon_{0}\vec{E}[/itex] inside the cavity, [itex]\vec{D}_{0}=\epsilon_{0}\vec{E}_{new}[/itex].
a. This part was simple. Inside a polarized sphere, [itex]\vec{E}=\frac{-1}{3\epsilon_{0}} \vec{P}[/itex], so [itex]\vec{E}_{new}=\vec{E}_{0}+\frac{1}{3\epsilon_{0}} \vec{P}[/itex], and [itex]\vec{D}=\vec{D}_{0}-\frac{2}{3}\vec{P}[/itex].b. Here it gets more tricky. The length of the needle is parallel to [itex]\vec{P}[/itex], so the [itex]\vec{E}[/itex] is pointed into and outside the ends. There would be a - charge and + charge at opposite ends, creating a field between them. But the field is negligible because the distance between them is large compared to the dipole? In that case, [itex]\vec{E}_{new}=\vec{E}_{0}[/itex]. Once we neglect the field inside, I can move forward, but can anyone explain better why exactly we ignore that field.
c. Now we have a thin wafer-shaped cavity. I tried to use potential to calculate the electric field within the wafer.
[itex]V=\frac{1}{4\pi\epsilon_{0}}\oint_{S}\frac{1}{r} \vec{P}\cdot d\vec{a}[/itex].
(I did not use the second half of this eqn because we are assuming uniform polarization, which means the gradient of polarization is 0.)
From here I find
[itex]\vec{E}=-\vec{\triangledown}V=\frac{-1}{2\epsilon_{0}}\vec{P}[/itex].
I then multiplied this by 2 to account for the top and bottom sides of the wafer and found
[itex]\vec{E}_{new}=\vec{E}+\frac{1}{\epsilon_{0}}\vec{P}[/itex].
The answer is right, but I'm not sure about my work/reasoning.
I'm fixing the code currently
